coq-club - [Coq-Club] Problems with Fixpoint termination and Universe inconsistency.
chronological Thread
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Problems with Fixpoint termination and Universe inconsistency.
  • Date: Thu, 18 Feb 2010 20:54:18 +0100
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=EFmKDx8sCil9RWJvY/YwahCUd9yQCzLV9ntiI0va7LiXoAAxwlx4doprGxbpqIWUu+ gkDRbykqcIpoKkub7PZruTak1C7EzhkTlhUpfQiLBAlimJGhLnaC3+EghvLqAlHSBqmS U8ihAW7CV/E08B/SIW0AXCLvNpAtxp2iWjTTs=
   Dear list,
  I'm working with heterogenous lists, as defined in Adam Chlipala's
book CPDT. I'd like to define a function that takes a list of lists
[xs_1; ... xs_n] and produces a list containing all the lists of
the form [x_1; ... x_n] where [In x_1 xs_1 /\ ... /\ In x_n xs_n].
  For 'regular' lists this function can be straightforwardly defined as:
Require Import List Program.
Set Implicit Arguments.
Section List_prods.
  Variable A : Type.
  (* [list_combine [x_1; ... x_n] [y_1; ... y_n] = [x_1::y_1; ... x_n::y_n; x_2::y_1 ... x_n::y_n]] *)
  Fixpoint list_combine (l : list A) (l' : list (list A)) : list (list A) :=
    match l with
    | x::xs => List.map (fun y_i => x::y_i) l' ++ list_combine xs l'
    end.
  (* list_prod_tuple [xs_1; ... xs_n] gives a list containing every
     list of the form [x_1; ... x_n] where [In x_1 xs_1], ... [In x_n xs_n].
  Fixpoint list_prod_tuple (elts : list (list A)) : list (list A) :=
    match elts with
    | [x] => List.map (fun i => [i]) x
    | x::xs => list_combine x (list_prod_tuple xs)
    end.
End List_prods.
Eval vm_compute in list_prod_tuple [[1;2]; [3;4]].
 >  = [[1; 3]; [1; 4]; [2; 3]; [2; 4]]
 >  : list (list nat)
    However, when I try to generalize this to heterogenous lists I hit
  two problems (the listing is a tad longer so I attach it to this mail):
  1) Coq does not recognize that the principal argument is decreasing
     in the recursive call (although clearly it does).
   Dear list,
as:
Section List_prods.
  Variable A : Type.
    match l with
    end.
    match elts with
    end.
End List_prods.
 >  : list (list nat)
   Dear list,
as:
Section List_prods.
  Variable A : Type.
    match l with
    end.
    match elts with
    end.
End List_prods.
 >  : list (list nat)
  2) even when we forget about this, I run into Universe inconsistency
     problem...
   Any help appreciated,
    Adam
Adam Koprowski   [http://www.cs.ru.nl/~Adam.Koprowski]
R&D @ MLstate    [15 rue Berlier, 75013 Paris, France]
Sent from Montrouge, France
Attachment: list_lst1.v
Description: Binary data
