- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Re: Problems with Fixpoint termination and Universe inconsistency.
- Date: Thu, 18 Feb 2010 20:57:20 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:from:date:message-id:subject:to :content-type; b=DivVJY51zRkbRgC4zIBdyKtHtSaqTzuRtJrjw+W3cZnGtYAznN4iM3R8eLPgKxY0Z8 K/cgNTn1R8lVmT336By2bxEvUu+OjS3RJoDP2IM2eF9TZgnkLkku6CG4yJCKgYLrKwvK K1EngJ4wcstG8zXXaxF//WvbP/0jUHIdnYeCo=
Ups... sorry for the malformed post. It should read:
Dear list,
I'm working with heterogenous lists, as defined in Adam Chlipala's
book CPDT. I'd like to define a function that takes a list of lists
[xs_1; ... xs_n] and produces a list containing all the lists of
the form [x_1; ... x_n] where [In x_1 xs_1 /\ ... /\ In x_n xs_n].
Require Import List Program.
Set Implicit Arguments.
Section List_prods.
Variable A : Type.
(* list_prod_tuple [xs_1; ... xs_n] gives a list containing every
list of the form [x_1; ... x_n] where [In x_1 xs_1], ... [In x_n xs_n].
End List_prods.
> = [[1; 3]; [1; 4]; [2; 3]; [2; 4]]
However, when I try to generalize this to heterogenous lists I hit
two problems (the listing is a tad longer so I attach it to this mail):
1) Coq does not recognize that the principal argument is decreasing
in the recursive call (although clearly it does).
2) even when we forget about this, I run into Universe inconsistency
problem...
For 'regular' lists this function can be straightforwardly defined
as:
Section List_prods.
Variable A : Type.
(* [list_combine [x_1; ... x_n] [y_1; ... y_n] = [x_1::y_1; ... x_n::y_n; x_2::y_1 ... x_n::y_n]] *)
Fixpoint list_combine (l : list A) (l' : list (list A)) : list (list A) :=
match l with
| x::xs => List.map (fun y_i => x::y_i) l' ++ list_combine xs l'
end.
Fixpoint list_prod_tuple (elts : list (list A)) : list (list A) :=
match elts with
| [x] => List.map (fun i => [i]) x
| x::xs => list_combine x (list_prod_tuple xs)
end.
End List_prods.
Eval vm_compute in list_prod_tuple [[1;2]; [3;4]].
> : list (list nat)
problem...
Any help appreciated,
Adam
Adam Koprowski [http://www.cs.ru.nl/~Adam.Koprowski]
R&D @ MLstate [15 rue Berlier, 75013 Paris, France]
Sent from Montrouge, France
- [Coq-Club] Problems with Fixpoint termination and Universe inconsistency., Adam Koprowski
- [Coq-Club] Re: Problems with Fixpoint termination and Universe inconsistency., Adam Koprowski
- Re: [Coq-Club] Problems with Fixpoint termination and Universe inconsistency., Bruno Barras
