coq-club - Re: [Coq-Club] Re: Problems with Fixpoint termination and Universe inconsistency.
chronological Thread
  • To: Adam Koprowski <adam.koprowski AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Re: Problems with Fixpoint termination and Universe inconsistency.
  • Date: Thu, 18 Feb 2010 15:20:38 -0500
Adam Koprowski wrote:
    However, when I try to generalize this to heterogenous lists I hit
  two problems (the listing is a tad longer so I attach it to this mail):
  1) Coq does not recognize that the principal argument is decreasing
     in the recursive call (although clearly it does).
  2) even when we forget about this, I run into Universe inconsistency
     problem...
   Any help appreciated,
    Adam
First, a simple type annotation gets Coq to accept your definition of [hlist_combine], with no need for [Program]. This is the [: id t] explicit ascription, which helps avoid the need to solve a higher-order unification problem. You could get the same effect by applying [HCons] with the [B] parameter specified explicitly.
  Fixpoint hlist_combine t (l : list t)
    : forall ts, list (hlist id ts) -> list (hlist id (t::ts)) :=
    match l return
    with
    | [] => fun _ _ => []
    | x::xs => fun _ l' =>
        map (fun y_i => (x : id t) ::: y_i) l' ++ hlist_combine xs l'
    end.
For the universe inconsistency, I'm a bit stumped by this one, but there is an easy workaround that is probably acceptable. The following type works fine, apparently because Coq's fake universe polymorphism elaborates it differently.
  forall l : list Type, hlist (fun T => list T) l -> list (hlist id l)
Finally, here's a (probable) definition of your final [hlist_prod_tuple]. I haven't thought through whether this does exactly what you want, but it probably provides a starting point.
Fixpoint hlist_prod_tuple (l : list Type) (hl : hlist (fun T => list T) l) : list (hlist id l) :=
    match hl in hlist _ l return list (hlist id l) with
      | HNil => [HNil]
      | HCons _ _ v hl' => hlist_combine v (hlist_prod_tuple hl')
    end.
It's generally better to write a function as explicitly recursive in an [hlist], rather than just on the [hlist]'s [list] index, when possible.
