- To: Adam Koprowski <adam.koprowski AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Problems with Fixpoint termination and Universe inconsistency.
- Date: Fri, 19 Feb 2010 11:02:10 +0100
Adam Koprowski wrote:
Hello,
(* list_prod_tuple [xs_1; ... xs_n] gives a list containing every list of the form [x_1; ... x_n] where [In x_1 xs_1], ... [In x_n xs_n].
Fixpoint list_prod_tuple (elts : list (list A)) : list (list A) :=
match elts with
| [x] => List.map (fun i => [i]) x
| x::xs => list_combine x (list_prod_tuple xs)
end.
You have to be aware that dependent and non-dependent match have quite different heuristics. Here, since your second branch uses pattern [x], in the dependent case, the third branch's pattern is indeed (x::x0::xs0) (modulo renaming of pattern variables) and xs is replaced by (x0::xs0) in the rhs. Hence the error message.
Regarding the universe inconsistency, as Adam C. said, eta-expanding list does it:
Variable hlist_prod_tuple_ax : forall l : list Type,
hlist (fun A => list A) l -> list (hlist id l).
Eta-expansions creates a fresh universe (the type of A), and the sort-polymorphism now applies because list is applied to its parameter. When list is not expanded, then it belongs to a fixed universe that must be constrained somewhere else in your script.
Eta-expansion saved you this time, but there's probably something you don't expect in your definition of heterogeneous lists, and it'll probably bite you later on. You have
Variable A : Type. (* Type_a *)
Variable B : A -> Type (* Type_b *).
Inductive hlist : list A -> Type (* Type_c *):=
| HNil : hlist nil
| HCons : forall x xs, B x -> hlist xs -> hlist (x::xs).
The predicativity constraint on hlist put hlist in a universe higher or equal to that of A (arguments x and xs of HCons). Formally,
Type_c >= max(Type_a, Type_b).
In your case, A = Type_A, B= fun A (*:Type_A*) => list A,
so Type_a > Type_A and Type_b >= Type_A, so in the end Type_c > Type_A. Your hlist type lives in a universe strictly higher than the types of the arity!
In fact Adam C.'s definition of heterogeneous lists is useful when A (representing code of the arity types) lives in a universe lower than B (the decoding function): Type_a <= Type_b.
You can relax this constraint with the following definition (not resorting to the type encoding):
Inductive hlist (l:list Type (* Type_l *)) : Type (* Type_c *) :=
HNil: l=nil -> hlist l
| HCons: l<>nil -> List.hd unit l -> hlist (List.tl l) -> hlist l.
Note that l is a (non-recursive) parameter, so it does not appear as a real argument of constructors. The only constraint is Type_c >= Type_l (because List.hd unit l : Type_l).
Hope this helps,
Bruno Barras.
- [Coq-Club] Problems with Fixpoint termination and Universe inconsistency., Adam Koprowski
- [Coq-Club] Re: Problems with Fixpoint termination and Universe inconsistency., Adam Koprowski
- Re: [Coq-Club] Problems with Fixpoint termination and Universe inconsistency., Bruno Barras
