coq-club - [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
  • Date: Sat, 8 May 2010 17:19:45 +0900
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:date:x-google-sender-auth:message-id:subject :from:to:content-type; b=IWuvm8eQ/uegBosFlGuZrVPvZSNbikEe8MH/9DO3/BP5vnGv21c+mCybsDyCZikilY bTO2na4gFqNH4SsvYCePRXsIp3m+ZMCj6BuxfgPkUZ8CUnsbHVd2HzPfHdDe0jXp03aU bjc5UFxcjSrA0BYiXC6/PEUc3N5UjAjd2K9wA=
Hi,
I have encountered 3 three cases which I could handle with some
reflection, but I think it would be interesting, not just for me, to
know how you would solve them.
Here are the three.
1) For a term construction, assume you have used eq_rect with a proof
H as in the following
eq_rect x P t x H
But if H is not syntactically equal to refl_equal, then simpl tactic
won't convert the term above to t.
Is proof-irrelevance necessary to get the reduction?
2) It's about eq's polymorphism.
Coq complained once that [nat = nat] is different from [nat = nat].
Then using Set Printing All, I found out Coq was right because
@eq Set nat nat and @eq Type nat nat are syntactically different.
However how should I understand this apart from that syntactic inequality?
3) Assume the goal is to show
JMeq t s
and you know t = t'. Is there any tactic which functions like rewrite
for the usual equality?
You could work with JMeq_ind, and there are some explanations in
CoqArt, Section 8.2.7, how to deal with it.
But I am wondering if some tactics have been developed in the meantime.
Thanks for any comments in advance.
Gyesik
