coq-club - Re: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
chronological Thread
  • From: "Chung Kil Hur" <Chung-Kil.Hur AT pps.jussieu.fr>
  • To: "Gyesik Lee" <gslee AT ropas.snu.ac.kr>
  • Cc: <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
  • Date: Sun, 9 May 2010 22:57:51 +0200
Hi Gyesik,
> 1) For a term construction, assume you have used eq_rect with a proof
> H as in the following
> eq_rect x P t x H
> But if H is not syntactically equal to refl_equal, then simpl tactic
> won't convert the term above to t.
> Is proof-irrelevance necessary to get the reduction?
You don't need the general proof irrelevance.
You just need a much weaker assumption, the uniqueness of identity
proof~(UIP),
or equivalently Streicher's Axiom K, to derive H = refl_equal.
Actually, in Agda, this axiom is internalized (ie, H is convertible to
refl_equal) and
I heard that it is going to be internalized in a later version of Coq as well.
> 3) Assume the goal is to show
> JMeq t s
> and you know t = t'. Is there any tactic which functions like rewrite
> for the usual equality?
> You could work with JMeq_ind, and there are some explanations in
> CoqArt, Section 8.2.7, how to deal with it.
> But I am wondering if some tactics have been developed in the meantime.
If your question is about rewriting tactics for JMeq, I developed something
similar.
The library Heq supports rewriting of heterogeneous equality.
You can find it in the following address.
http://www.pps.jussieu.fr/~gil/Heq
But, you should use equality on dependent pairs instead of JMeq, which is
usually not a big deal.
Cheers,
Chung-Kil Hur
