coq-club - Re: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
chronological Thread
  • To: Gyesik Lee <gslee AT ropas.snu.ac.kr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
  • Date: Sat, 8 May 2010 11:07:13 +0200
Hi Gyesik,
On May 8, 2010, at 10:19 AM, Gyesik Lee wrote:
I have encountered 3 three cases which I could handle with some
reflection, but I think it would be interesting, not just for me, to
know how you would solve them.
Here are the three.
1) For a term construction, assume you have used eq_rect with a proof
H as in the following
eq_rect x P t x H
But if H is not syntactically equal to refl_equal, then simpl tactic
won't convert the term above to t.
Is proof-irrelevance necessary to get the reduction?
I am considering an extension of type theory where this term would reduce, because
  H : x = x
is eta-expanded to refl_equal.
@InProceedings{abel:nbe09,
  author =       {Andreas Abel},
title = {Extensional Normalization in the Logical Framework with Proof Irrelevant Equality},
booktitle = {Workshop on Normalization by Evaluation, affiliated to LiCS 2009, Los Angeles, 15 August 2009},
  year =         2009,
  editor =       {Olivier Danvy}
There is a prototypical implementation, MiniAgda:
  http://www2.tcs.ifi.lmu.de/~abel/miniagda/
2) It's about eq's polymorphism.
Coq complained once that [nat = nat] is different from [nat = nat].
Then using Set Printing All, I found out Coq was right because
@eq Set nat nat and @eq Type nat nat are syntactically different.
However how should I understand this apart from that syntactic inequality?
This is a bit harder. A priori, it is natural to assume these two types are different, in the same way as vect Set n and vect Type n are different. The only reason why these type could be equal because they are both singleton sets, namely { refl_equal }. But then, one would need a type theory that unifies all singletons, which smells very extensional.
Cheers,
Andreas
3) Assume the goal is to show
JMeq t s
and you know t = t'. Is there any tactic which functions like rewrite
for the usual equality?
You could work with JMeq_ind, and there are some explanations in
CoqArt, Section 8.2.7, how to deal with it.
But I am wondering if some tactics have been developed in the meantime.
Thanks for any comments in advance.
Gyesik
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
