coq-club - Re: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] eq_rect, proof-irrelevance, JMeq and rewriting
  • Date: Sat, 08 May 2010 12:22:54 +0200
Gyesik Lee wrote:
Hi,
I have encountered 3 three cases which I could handle with some
reflection, but I think it would be interesting, not just for me, to
know how you would solve them.
Here are the three.
1) For a term construction, assume you have used eq_rect with a proof
H as in the following
eq_rect x P t x H
But if H is not syntactically equal to refl_equal, then simpl tactic
won't convert the term above to t.
Is proof-irrelevance necessary to get the reduction?
Just for this question, proof irrelevance is only used to prove that H is equal to refl_equal x. So a restricted statement, strong enough for this result, may be used to avoid general proof irrelevance.
For instance, for any type t with a decidable equality (teq:forall x y:t, {x=y}+{x<>y}), you can prove the
following statement: forall x:t, forall p1 p2: x= x, p1 = p2, and this is enough to solve your problem.
Yves
