- To: Taral <taralx AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] connecting the dots between Fixpoint definitions
- Date: Sun, 11 Jul 2010 15:05:23 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type; b=l8S7mInTrXzYGSCnBQ0+ecbwyIqPHtH8/xpKB3k28QlCb4ZEG5mfDsfA5xNsTAhf+U OLyp5sdOI0xAZ62Osk0+pWKlFNiAgECxb56k7A6J+7di0jZFEg+NlWN3blt29voUZofE aGrf2HUT4oskIzfLItG3CuDcK1/rXHLLxFD9U=
It is just about remembering that if f is decreasing and g is
decreasing then f composed with g is also decreasing. Coq has a lot of
nice general rules that it applies quite elegantly in various modules
so it is somewhat surprising that it does not do it in this case.
> This isn't about n > n0, it's about n = S (S (S ... (S n0))) for some
> non-zero number of S's.
Given that Coq knows that S x > x, "n>n0" should be inferred as
equivalent to "n = S (S (S ... (S n0)))" by the induction rule on nat,
shouldn't it?
Paul
On 7/11/10, Taral
wrote:
> On Sun, Jul 11, 2010 at 12:28 PM, Paul Tarau
> <paul.tarau AT gmail.com>
> wrote:
>> After graciously saying that
>> "half is recursively defined (decreasing on 1st argument)"
> This means that the x in "S (half x)" is smaller than the n you passed in.
>> "Recursive call to buggy has principal argument equal to
>> "half n0" instead of n0"
> This means that "half n0" (the principal argument in the recursive
> call) cannot be inferred to be structurally smaller than n (the
> principal argument of the main call).
> non-zero number of S's. And the only inference coq will do is
> inspection of match clauses.
> I'm sure someone here will explain the nature of the structural
> fixpoint better than I could...
> Taral
> "Please let me know if there's any further trouble I can give you."
> -- Unknown
- [Coq-Club] connecting the dots between Fixpoint definitions, Paul Tarau
- Re: [Coq-Club] connecting the dots between Fixpoint definitions,
Taral
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, Paul Tarau
- RE: [Coq-Club] connecting the dots between Fixpoint definitions,
Georges Gonthier
Paul Tarau
Georges Gonthier
- RE: [Coq-Club] connecting the dots between Fixpoint definitions, Georges Gonthier
Georges Gonthier
Paul Tarau
Georges Gonthier
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, julien forest
Taral
