- To: julien forest <forest AT ensiie.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] connecting the dots between Fixpoint definitions
- Date: Mon, 12 Jul 2010 18:07:54 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=kCcnJQhjfh5dkVCNEYmsOFTAcfeWc0X00bTxjqfsdBLv3dS5GN8TOsJ++WPXRKDZpN fYqo7EpQsCylksexVrzz9V+OvpMsqJZcaz4Zl2oImypK5KIDpxhKkUOz+M8rlCvSqxuc 0xCyJWN4mPzj6u5ToYNoexLLwloP8rZqGQINc=
Many thanks for your help (and also to Georges and Taral) - everything works
now
resulting in a simple arithmetic theory of cons,hd, tail:
Require Import Bool.
Require Import Recdef.
Require Import Arith.
Fixpoint evenN (n: nat) {struct n} : bool :=
match n with
| O => true
| S O => false
| S (S x) => evenN x
end.
(* half, rounded up *)
Function halfUpN (n : nat) : nat :=
match n with
| O => O
| S O => S O
| S (S x) => S (halfUpN x)
end.
Lemma halfUpN_decrease :
forall n, halfUpN n <= n.
Proof.
intros n.
functional induction (halfUpN n);
auto with arith.
Qed.
(* returns x such that 2^x*... = n *)
Function hdN (n:nat) {measure (fun n => n) n} : nat :=
match n with
| O => O
| S x => if evenN x then O else S (hdN (halfUpN x))
end.
Proof.
intros n n' H1 H2.
apply le_lt_trans with n'.
apply halfUpN_decrease.
auto with arith.
Defined.
(* returns y, such that 2^...(2*y+1) = n *)
Function tlN (n:nat) {measure (fun n => n) n} : nat :=
match n with
| O => O
| S x => if evenN x then halfUpN x else tlN (halfUpN x)
end.
Proof.
intros n n' H1 H2.
auto with arith.
Defined.
Fixpoint plusN (n m : nat) {struct n} : nat :=
match n with
| O => m
| (S x) => S (plusN x m)
end.
Definition doubleN (n:nat) : nat := plusN n n.
Fixpoint multN (n m: nat) : nat :=
match n with
| O => O
| S x => plusN m (multN x m)
end.
Fixpoint exp2 (n:nat) {struct n} : nat :=
match n with
| O => S O
| S n => doubleN (exp2 n)
end.
(* reverses the effect of hdN and tlN i.e. consN (hdN n) (tlN n) is n *)
Definition consN (x y : nat) : nat := multN (exp2 x) (S (doubleN y)).
My next challenge is to prove "list-like" properties, for instance:
Fixpoint eqN (n m:nat) {struct n} : Prop :=
match n,m with
| O, O => True
| O, S _ => False
| S _, O => False
| S x, S y => eqN x y
end.
Lemma cons_hd_tl :
forall n, eqN n (consN (hdN n) (tlN n)).
In this case is it a good idea to define eqN by structural
induction or the built-in "=" relation should be used?
Paul
On Mon, Jul 12, 2010 at 1:59 PM, julien forest
wrote:
> Hi,
> On Mon, 12 Jul 2010 11:56:38 -0500
> Paul Tarau
>Â <paul.tarau AT gmail.com>
> wrote:
>> An interesting thing with this functional induction version is that
>> when trying something like:
>> Eval compute in buggy 360.
>> Coq 8.1pl2 on a Mac returns
>> =1 (incorrectly)
> No, this is correct.
> Try this command to see the unfolding of the function definition and
> evaluation:
> Goal buggy 360 = 1.
> rewrite buggy_equation. (* first recursion on 359 *)
> simpl.
> rewrite buggy_equation. (* second recursion on (half 359) -1 i.e. 178
> which is even *)
> simpl.
> Qed.
>> while
>> Coq 8.2 (February 2009) on a Mac returns
>> = let (v, _) := buggy_terminate 360 in v
>> : nat
>> which, I suppose needs to be further reduced or it just states
>> "I do not know what the value is but I know it will terminate".
> My mistake, you should end the proof after the definition of buggy by
> Defined and not Qed.
>> Does 8.3 beta work correctly on such functional induction examples?
> yes of course. In fact, they have been defined using coq trunk.
> Best regards,
> Julien.
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, (continued)
Taral
Paul Tarau
- RE: [Coq-Club] connecting the dots between Fixpoint definitions,
Georges Gonthier
Paul Tarau
Georges Gonthier
- RE: [Coq-Club] connecting the dots between Fixpoint definitions, Georges Gonthier
Georges Gonthier
Paul Tarau
Georges Gonthier
Paul Tarau
julien forest
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, Paul Tarau
Paul Tarau
julien forest
julien forest
Taral
