coq-club - Re: [Coq-Club] connecting the dots between Fixpoint definitions
chronological Thread
  • To: julien forest <forest AT ensiie.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] connecting the dots between Fixpoint definitions
  • Date: Mon, 12 Jul 2010 11:56:38 -0500
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=mGYfgh2jNZixQ9gB92OmyCyMHW3V/NywsNfZpoaIj3F84xig2j2Tf939PeepWlKyTu 2MX8ImI45XfWGXEx5JQIXfPVgVZ9zIuNLxTqdU8FVAj5r7Os2UtZ2VHEvIi0bpwJxZBy 2KLAzNzDubhzUcz84YzC0wbtIe+95smAferjg=
An interesting thing with this functional induction version is that when
trying
something like:
Eval compute in buggy 360.
Coq 8.1pl2 on a Mac returns
=1 (incorrectly)
while
Coq 8.2 (February 2009) on a Mac returns
   = let (v, _) := buggy_terminate 360 in v
     : nat
which, I suppose needs to be further reduced or it just states
"I do not know what the value is but I know it will terminate".
Does 8.3 beta work correctly on such functional induction examples?
Paul
On Sun, Jul 11, 2010 at 4:25 PM, julien forest
 wrote:
> Dear Paul,
> On Sun, 11 Jul 2010 14:28:39 -0500
> Paul Tarau
> <paul.tarau AT gmail.com>
>  wrote:
>> Dear Coq users,
>> When trying to port some simple code from Haskell to Coq
>> I have noticed that it does not propagate what it knows
>> about a function ("half" in the following example) to
>> another function ("buggy" in the example).
>> Require Import Bool.
>> Fixpoint isEven (n: nat) {struct n} : bool :=
>> match n with
>> | 0 => true
>> | 1 => false
>> | S (S n) => isEven n
>> end.
>> Fixpoint half (n  : nat) : nat :=
>>   match n with
>>   | O => 0
>>   | S O => 0
>>   | S (S x) => S (half x)
>>   end.
>> Fixpoint buggy (n:nat) {struct n} : nat :=
>> match n with
>> | 0 => 0
>> | S n => if isEven n then 0 else S (buggy (half n))
>> end.
>> After graciously saying that
>> "half is recursively defined (decreasing on 1st argument)"
> At this point, this probably only means that coq found that n is the
> only POSSIBLE decreasing argument.
>> it complains that
>> "Recursive call to buggy has principal argument equal to
>> "half n0" instead of n0"
>> The system clearly knows that "S n" decreases to "n" and it
>> is also acknowledging that "half is decreasing" but it does
>> not seem to connect the dots and accept "half n"
>> as an argument in the recursive call to "buggy".
> No, for structural induction coq (mostly) only accepts recursive
> definitions which recurse only on syntactically smaller arguments. Here
> buggy can only recurse on n.
> The fact that (half n) is smaller than n is not so obvious and in fact
> needs an inductive proof. Coq cannot guess this for you and thus you
> cannot use structural fixpoint to define such a function.
> You can use non structural induction to define buggy (Function or
> Program Fixpoint).
> For example, the following code will work fine and define the
> function (I added a call to functionnal induction to show the
> advantages on using Function):
> match n with
> | 0 => true
> | 1 => false
> end.
> Function half (n  : nat) : nat :=
>  match n with
>  | O => 0
>  | S O => 0
>  end.
> Require Import Recdef.
> Require Import Arith.
> Lemma half_decrease :
>  forall n, half n <= n.
> Proof.
>  intros n.
>  functional induction (half n);
>  auto with arith.
> Qed.
> Function buggy (n:nat) {measure (fun n => n) n} : nat :=
> match n with
> | 0 => 0
> end.
> Proof.
>  intros n n' H1 H2.
>  apply le_lt_trans with n'.
>  apply half_decrease.
>  auto with arith.
> Qed.
>> Can anyone suggest a simple workaround to the problem?
> Hope this help,
> Regards,
> Julien
