- To: julien forest <forest AT ensiie.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] connecting the dots between Fixpoint definitions
- Date: Sun, 11 Jul 2010 19:42:45 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=neEgpHkeVCViTIjlSX/o/87S3qOpyTTLVwFnFTjZCihF9AOQl78bqJAifnCY9UIYeW xoTU+jdeP71bLYRT/GddKJUZYM3Uxev0Ztb9snAy7zQ8avRV/EnuhujNENoeIfaKtitQ fQk9fSB7APH02Rho040dGU1Jyp5taXb0FrIWQ=
Thanks a lot, it helps indeed. And the "pattern" in your code seems reusable
to
handle various cases of legitimate recursion. Maybe this can all be
encapsulated
in a language construct that generates such proofs automatically?
Paul
On Sun, Jul 11, 2010 at 4:25 PM, julien forest
wrote:
> Dear Paul,
> On Sun, 11 Jul 2010 14:28:39 -0500
> Paul Tarau
>Â <paul.tarau AT gmail.com>
> wrote:
>> Dear Coq users,
>> When trying to port some simple code from Haskell to Coq
>> I have noticed that it does not propagate what it knows
>> about a function ("half" in the following example) to
>> another function ("buggy" in the example).
>> Require Import Bool.
>> Fixpoint isEven (n: nat) {struct n} : bool :=
>> match n with
>> | 0 => true
>> | 1 => false
>> | S (S n) => isEven n
>> end.
>> Fixpoint half (n : nat) : nat :=
>> match n with
>> | O => 0
>> | S O => 0
>> | S (S x) => S (half x)
>> end.
>> Fixpoint buggy (n:nat) {struct n} : nat :=
>> match n with
>> | 0 => 0
>> | S n => if isEven n then 0 else S (buggy (half n))
>> end.
>> After graciously saying that
>> "half is recursively defined (decreasing on 1st argument)"
> At this point, this probably only means that coq found that n is the
> only POSSIBLE decreasing argument.
>> it complains that
>> "Recursive call to buggy has principal argument equal to
>> "half n0" instead of n0"
>> The system clearly knows that "S n" decreases to "n" and it
>> is also acknowledging that "half is decreasing" but it does
>> not seem to connect the dots and accept "half n"
>> as an argument in the recursive call to "buggy".
> No, for structural induction coq (mostly) only accepts recursive
> definitions which recurse only on syntactically smaller arguments. Here
> buggy can only recurse on n.
> The fact that (half n) is smaller than n is not so obvious and in fact
> needs an inductive proof. Coq cannot guess this for you and thus you
> cannot use structural fixpoint to define such a function.
> You can use non structural induction to define buggy (Function or
> Program Fixpoint).
> For example, the following code will work fine and define the
> function (I added a call to functionnal induction to show the
> advantages on using Function):
> match n with
> | 0 => true
> | 1 => false
> | S (S n) => isEven n
> end.
> Function half (n : nat) : nat :=
> match n with
> | O => 0
> | S O => 0
> end.
> Require Import Recdef.
> Require Import Arith.
> Lemma half_decrease :
> forall n, half n <= n.
> Proof.
> intros n.
> functional induction (half n);
> auto with arith.
> Qed.
> Function buggy (n:nat) {measure (fun n => n) n} : nat :=
> match n with
> | 0 => 0
> end.
> Proof.
> intros n n' H1 H2.
> apply le_lt_trans with n'.
> apply half_decrease.
> auto with arith.
> Qed.
>> Can anyone suggest a simple workaround to the problem?
> Hope this help,
> Regards,
> Julien
- [Coq-Club] connecting the dots between Fixpoint definitions, Paul Tarau
- Re: [Coq-Club] connecting the dots between Fixpoint definitions,
Taral
Paul Tarau
- RE: [Coq-Club] connecting the dots between Fixpoint definitions,
Georges Gonthier
Paul Tarau
Georges Gonthier
- RE: [Coq-Club] connecting the dots between Fixpoint definitions, Georges Gonthier
Georges Gonthier
Paul Tarau
Georges Gonthier
Paul Tarau
julien forest
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, Paul Tarau
Paul Tarau
julien forest
julien forest
Taral
