- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: julien forest <forest AT ensiie.fr>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] connecting the dots between Fixpoint definitions
- Date: Tue, 13 Jul 2010 10:10:01 -0500
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:in-reply-to:references:date:message-id:subject:from:to :cc:content-type:content-transfer-encoding; b=qcEULLPY9HKpb+CH6Ynu/V/D9FdyxGRUhMsdAsRmDyzkhfnB/HJ0Lkwv6rf3e7ZSnn 7J+0eBsZP0JOBTTi7ImPVUyx8pyNF+sMjv2xXh7biiJdO8jjWE3udjtxqB3rHLbJvrTm tf0PQISgSnOfVzN3D4d7mOFh/Qra0McvS2DqU=
In my original Haskell code hdN 0 = error and tlN 0 = error. So the Lemma
should be:
Lemma cons_hd_tl :
forall n, n>0 -> consN (hdN n) (tlN n) = n.
Paul
On Tue, Jul 13, 2010 at 5:32 AM, AUGER Cedric
wrote:
> Le Mon, 12 Jul 2010 18:07:54 -0500,
> Paul Tarau
>Â <paul.tarau AT gmail.com>
> a écrit :
>> Many thanks for your help (and also to Georges and Taral) -
>> everything works now resulting in a simple arithmetic theory of
>> cons,hd, tail:
>> Require Import Bool.
>> Require Import Recdef.
>> Require Import Arith.
>> Fixpoint evenN (n: nat) {struct n} : bool :=
>> match n with
>> | O => true
>> | S O => false
>> | S (S x) => evenN x
>> end.
>> (* half, rounded up *)
>> Function halfUpN (n : nat) : nat :=
>> match n with
>> | O => O
>> | S O => S O
>> | S (S x) => S (halfUpN x)
>> end.
>> Lemma halfUpN_decrease :
>> forall n, halfUpN n <= n.
>> Proof.
>> intros n.
>> functional induction (halfUpN n);
>> auto with arith.
>> Qed.
>> (* returns x such that 2^x*... = n *)
>> Function hdN (n:nat) {measure (fun n => n) n} : nat :=
>> match n with
>> | O => O
>> | S x => if evenN x then O else S (hdN (halfUpN x))
>> end.
>> Proof.
>> intros n n' H1 H2.
>> apply le_lt_trans with n'.
>> apply halfUpN_decrease.
>> auto with arith.
>> Defined.
>> (* returns y, such that 2^...(2*y+1) = n *)
>> Function tlN (n:nat) {measure (fun n => n) n} : nat :=
>> match n with
>> | O => O
>> | S x => if evenN x then halfUpN x else tlN (halfUpN x)
>> end.
>> Proof.
>> intros n n' H1 H2.
>> auto with arith.
>> Defined.
>> Fixpoint plusN (n m : nat) {struct n} : nat :=
>> match n with
>> | O => m
>> | (S x) => S (plusN x m)
>> end.
>> Definition doubleN (n:nat) : nat := plusN n n.
>> Fixpoint multN (n m: nat) : nat :=
>> match n with
>> | O => O
>> | S x => plusN m (multN x m)
>> end.
>> Fixpoint exp2 (n:nat) {struct n} : nat :=
>> match n with
>> | O => S O
>> | S n => doubleN (exp2 n)
>> end.
>> (* reverses the effect of hdN and tlN i.e. consN (hdN n) (tlN n) is n
>> *) Definition consN (x y : nat) : nat := multN (exp2 x) (S (doubleN
>> y)).
>> My next challenge is to prove "list-like" properties, for instance:
>> Fixpoint eqN (n m:nat) {struct n} : Prop :=
>> match n,m with
>> | O, O => True
>> | O, S _ => False
>> | S _, O => False
>> | S x, S y => eqN x y
>> end.
>> Lemma cons_hd_tl :
>> forall n, eqN n (consN (hdN n) (tlN n)).
>> In this case is it a good idea to define eqN by structural
>> induction or the built-in "=" relation should be used?
>> Paul
> Some piece of advice, don't rush with such definitions:
> I suspect there is some glich in your cons_hd_tl:
> If I am right,
> . tlN 0 = 0
> . hdN 0 = 0
> . consN 0 0 = 1
> but 0 is not 1.
> In fact, your specification of tlN is wrong:
> there is no y such that there is x such that
> x
> 2.(2.y+1) = 0
> and you write that y works in your definition.
> So you should adapt your lemma, to make it provable
> (or find inconsistency in Coq).
- RE: [Coq-Club] connecting the dots between Fixpoint definitions, (continued)
Georges Gonthier
- RE: [Coq-Club] connecting the dots between Fixpoint definitions, Georges Gonthier
- Re: [Coq-Club] connecting the dots between Fixpoint definitions,
julien forest
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, Paul Tarau
Paul Tarau
julien forest
Paul Tarau
Taral
- Re: [Coq-Club] connecting the dots between Fixpoint definitions, Martijn Vermaat
AUGER Cedric
Taral
Paul Tarau
julien forest
Georges Gonthier
