- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] About mutual recursion
- Date: Tue, 12 Oct 2010 02:40:28 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:from:date:message-id:subject:to:content-type; b=iuLVI8Vv3ALLdzES9XmSXBXGjn9x4ZhvyOckyBWG6GPiKhsZCn8cUMffG7wM3XBp8z MC9N4zmoy+HOeP2+u7yQtQAquRLM4wEMuqS/WrPmkb8kSn1chPGh9YFmlLiiFDrR3Ep5 Fe6Tjjb5NzWsPZUtsCBDFX9KfTBWWZN2C2NMo=
Hi,
I am not sure if the title of the message is adequate, so I apologize
in advance for any possible confusion.
(* Consider the following inductive definition.*)
Inductive toto : Type :=
Var : toto
| Unit : toto
| Plus : toto -> toto -> toto.
(* Now I would like to check if a (t : toto) contains [Var] or not.
One possible definition is as follows *)
Fixpoint VarIn (t:toto) : Prop :=
match r with
| Var => True
| Unit => False
| Plus t0 t1 => (VarIn t0) \/ (VarIn t1)
end.
(* What I don't like with this definition is that I don't have the
proof unicity without using proof-irrelevance.
This doesn't mean that I don't like proof-irrelevance.
Lemma VarIn_unicity : forall (t : toto) (p q : VarIn t), p = q.
I am just curious because, on the other hand, the predicate [VarIn]
is decidable, i.e. *)
Lemma VarIn_dec : forall t, {VarIn t} + {~ VarIn t}.
Proof.
induction t; simpl; firstorder.
Qed.
(* Because of this, I am wondering if a definition like below is
somehow possible:
match r with
| Var => True
| Unit => False
| Plus t0 t1 => if {VarIn t0} + {~ VarIn t0} then True else (VarIn t1)
end.
which would provide me with proof-unicity. So I thought, maybe using
mutual recursion would be possible in the following form:
match t with
| Var => _
| Unit => _
| Plus t0 t1 => _
end
with VarIn_dec (t:toto) : {VarIn t} + {~ VarIn t} :=
match t with
| Var => _
| Unit => _
| Plus t0 t1 => _
end.
But this is not allowed in Coq. *)
It would be nice if someone tells me if I am trying something possible.
Gyesik
- [Coq-Club] About mutual recursion, Gyesik Lee
- Re: [Coq-Club] About mutual recursion,
Adam Chlipala
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Gyesik Lee
Adam Chlipala
- Re: [Coq-Club] About mutual recursion, AUGER Cedric
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Thorsten Altenkirch
- Re: [Coq-Club] (Not) About mutual recursion, Jean-Francois Monin
Adam Chlipala
