- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] About mutual recursion
- Date: Tue, 12 Oct 2010 04:20:02 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=W56NDeRMcPDJ8iaCSlIF/ZZY+aFRZyrr2UzSt36ls6BU02UArj5XmbYzaxjZL4A5XQ sIbIwZYg6veADy2Ck7TAuMdl732TqdOdAIa1Qstp+qGI4tuw3alfe86FQjXmWR+5HgNF 391S42eZd+X2toflnwAjtQy7RvuhT74Erq7kQ=
Hi Adam,
> This property doesn't even type-check for [bool], but it's a mistake to
> conclude that it isn't easy to "use [bool]s as types." Just use the boolean
> as the index to this type family:
> Inductive sing : bool -> Type := Sing : sing true.
> There are other encodings you could consider, too.
Yes, you are right. It was my mistake to have ruled out the boolean.
Although I didn't succeed in making direct use of [sing] or similar
things, I got another idea.
I just defined a boolean version of [VarIn] and used it to do a decision.
Here is my solution.
Fixpoint bVarIn (r:Rep) : bool :=
match r with
| Var => true
| Plus r0 r1 => if (bVarIn r0) then true else (bVarIn r1)
| Unit => false
end.
Fixpoint VarIn (r:Rep) : Prop :=
match r with
| Var => True
| Plus r0 r1 => if (bVarIn r0) then VarIn r0 else VarIn r1
| Unit => False
end.
Then the proof unicity is simple to prove.
Lemma VarIn_unicity : forall r (p q : VarIn r), p = q.
Many thanks for useful helps.
Gyesik
2010/10/12 Adam Chlipala
<adam AT chlipala.net>:
> Gyesik Lee wrote:
>>> Why don't you just use [bool] instead of [Prop]?
>> because I want to have the property that there is no term of type
>> [VarIn r] when its value is False.
>> But this does not work with the Boolean [false].
- [Coq-Club] About mutual recursion, Gyesik Lee
- Re: [Coq-Club] About mutual recursion,
Adam Chlipala
Gyesik Lee
Adam Chlipala
- Re: [Coq-Club] About mutual recursion, Gyesik Lee
Adam Chlipala
- Re: [Coq-Club] About mutual recursion, AUGER Cedric
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Thorsten Altenkirch
- Re: [Coq-Club] (Not) About mutual recursion,
Jean-Francois Monin
- Re: [Coq-Club] (Not) About mutual recursion, Gyesik Lee
Adam Chlipala
