- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: Gyesik Lee <leegys AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] (Not) About mutual recursion
- Date: Tue, 12 Oct 2010 23:40:21 +0800
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=sender:date:from:to:cc:subject:message-id:references:mime-version :content-type:content-disposition:in-reply-to:user-agent; b=iGDoQz5l+rEERPX9HdpTBWEmqbk4vuthOST3eQDjyJRfWTFvA+Oc8CHwRLYQhquGWG 5zgFNfL5odognrI1QMUg7Zdz55gyDngHXS3S3TMuADedVEU8KyB39FtDCVU6tbMQRA0F Q3jR5d6HQMjHXoH9rBXIwqmqqJRlRe2qNw2xU=
Hello,
There is a simple solution without bool.
Fixpoint VarInk (t:toto) : Prop -> Prop :=
fun A =>
match t with
| Var => True
| Unit => A
| Plus t0 t1 => (VarInk t0 (VarInk t1 A))
end.
What you want is (VarInk t False).
Proving
Lemma VarInk_unicity :
forall (t : toto) (A: Prop), unicity A -> unicity (VarInk t A).
is a piece of cake.
Of course
Definition unicity (P:Prop) := forall (p q: P), p=q.
If you need the equivalence with your
original definition, just prove (rather simple):
Lemma varin_varink : forall t A, VarIn t \/ A -> VarInk t A.
Lemma varink_varin : forall t A, VarInk t A -> VarIn t \/ A.
Hope this helps,
JF
On Tue, Oct 12, 2010 at 02:40:28AM +0900, Gyesik Lee wrote:
> Hi,
> I am not sure if the title of the message is adequate, so I apologize
> in advance for any possible confusion.
> (* Consider the following inductive definition.*)
> Inductive toto : Type :=
> Var : toto
> | Unit : toto
> | Plus : toto -> toto -> toto.
> (* Now I would like to check if a (t : toto) contains [Var] or not.
> One possible definition is as follows *)
> Fixpoint VarIn (t:toto) : Prop :=
> match r with
> | Var => True
> | Unit => False
> | Plus t0 t1 => (VarIn t0) \/ (VarIn t1)
> end.
> (* What I don't like with this definition is that I don't have the
> proof unicity without using proof-irrelevance.
> This doesn't mean that I don't like proof-irrelevance.
> Lemma VarIn_unicity : forall (t : toto) (p q : VarIn t), p = q.
Jean-Francois Monin
CNRS-LIAMA, Project FORMES & Universite de Grenoble 1
Office 3-605, FIT, Tsinghua University
Haidian District, Beijing 100084, CHINA
Tel: +86 10 62 79 69 79 ext 605
Fax@LIAMA:
+86 10 6264 7458
- [Coq-Club] About mutual recursion, Gyesik Lee
- Re: [Coq-Club] About mutual recursion,
Adam Chlipala
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Gyesik Lee
Adam Chlipala
- Re: [Coq-Club] About mutual recursion, AUGER Cedric
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Thorsten Altenkirch
- Re: [Coq-Club] (Not) About mutual recursion, Jean-Francois Monin
- Re: [Coq-Club] (Not) About mutual recursion, Gyesik Lee
Adam Chlipala
