- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] About mutual recursion
- Date: Tue, 12 Oct 2010 04:22:48 +0900
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type :content-transfer-encoding; b=tRKTsJhj46vXj8ZhiSM/mB59xyRdYqnojBqHNkEUUfcttTv1x/eyv1yMPrWMa8oIbK J25kW9HvbuDYWcy7rai1BjHMtEk8WpALgaHDv9xrHWoIKUdpoqJwGFFkdb8OoL5SS3GQ u2GrBqvf5S0EwXi/aEQNYu1GmKEL+AIDd9ujY=
Sorry, there was some typos in my previous email.
[Rep] stands for [toto] in my first email.
(a problem of copy-and-paste)
Gyesik
2010/10/12 Gyesik Lee
<gslee AT ropas.snu.ac.kr>:
> Hi Adam,
>> This property doesn't even type-check for [bool], but it's a mistake to
>> conclude that it isn't easy to "use [bool]s as types." Just use the
>> boolean
>> as the index to this type family:
>> Inductive sing : bool -> Type := Sing : sing true.
>> There are other encodings you could consider, too.
> Yes, you are right. It was my mistake to have ruled out the boolean.
> Although I didn't succeed in making direct use of [sing] or similar
> things, I got another idea.
> I just defined a boolean version of [VarIn] and used it to do a decision.
> Here is my solution.
> Fixpoint bVarIn (r:Rep) : bool :=
> match r with
> | Var => true
> | Plus r0 r1 => if (bVarIn r0) then true else (bVarIn r1)
> | Unit => false
> end.
> Fixpoint VarIn (r:Rep) : Prop :=
> match r with
> | Var => True
> | Plus r0 r1 => if (bVarIn r0) then VarIn r0 else VarIn r1
> | Unit => False
> end.
> Then the proof unicity is simple to prove.
> Lemma VarIn_unicity : forall r (p q : VarIn r), p = q.
> Many thanks for useful helps.
> Gyesik
> 2010/10/12 Adam Chlipala
> <adam AT chlipala.net>:
>> Gyesik Lee wrote:
>>>> Why don't you just use [bool] instead of [Prop]?
>>> because I want to have the property that there is no term of type
>>> [VarIn r] when its value is False.
>>> But this does not work with the Boolean [false].
- [Coq-Club] About mutual recursion, Gyesik Lee
- Re: [Coq-Club] About mutual recursion,
Adam Chlipala
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Gyesik Lee
Adam Chlipala
- Re: [Coq-Club] About mutual recursion, AUGER Cedric
Gyesik Lee
Adam Chlipala
Gyesik Lee
- Re: [Coq-Club] About mutual recursion, Thorsten Altenkirch
- Re: [Coq-Club] (Not) About mutual recursion,
Jean-Francois Monin
- Re: [Coq-Club] (Not) About mutual recursion, Gyesik Lee
Adam Chlipala
