- To: St�phane Lescuyer <stephane.lescuyer AT inria.fr>
- Cc: staecker <cstaecker AT fairfield.edu>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] well-ordering of natural numbers
- Date: Thu, 14 Oct 2010 10:52:03 -0400 (EDT)
On Tue, 12 Oct 2010, Stéphane Lescuyer wrote:
I need to use a theorem like this:
Lemma nat_well_ordered: forall (P:nat -> Prop),
(exists n:nat, P n) -> (exists m:nat, P m /\
forall k:nat, P k -> k >= m).
Consider the fact that Coq's logic is intuitionistic, and try to think
of this theorem of yours in a constructive manner. If you're given an
n for which P is true, then how are you gonna compute the smallest k
for which P is true?
Indeed, you need to be able to decide if P is true on a given m to
write such a function. This is why you need the decidability of P to
prove this theorem.
If you're not interested in constructive logic, just assume the
excluded middle and using it you can use prove your theorem by a
simple induction on n.
Or alternatively you can avoid using axioms and instead use the weak (classical) existential:
Definition existsW (A:Type) (B : A -> Prop) : Prop := ~(forall x:A, ~ B x)
(forall n, ~~P n -> P n) ->
(existsW P) -> existsW (fun m:nat => P m /\
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- [Coq-Club] well-ordering of natural numbers, staecker
- Re: [Coq-Club] well-ordering of natural numbers,
Stéphane Lescuyer
- Re: [Coq-Club] well-ordering of natural numbers, AUGER
- Re: [Coq-Club] well-ordering of natural numbers, roconnor
Stéphane Lescuyer
