- To: Adam Chlipala <adam AT chlipala.net>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Binding variables within nested matches
- Date: Sat, 27 Nov 2010 08:11:36 +0000
Thanks Adam.
(I see now that this issue is mentioned in Section 12.3 of your book...)
--Ben
On 25 Nov 2010, at 19:57, Adam Chlipala wrote:
> Ben Moseley wrote:
>> match goal with | [ |- context [match ?d with
>> | Some _ => (match ?y with
>> | Left => true
>> | Right => true
>> end)
>> | None => true
>> end] ] => destruct d; [|reflexivity]
>> end.
>> ... then the match fails.
>> If instead I replace the '?y' with '_', then it succeeds.
> A term bound to a simple Ltac pattern variable isn't allowed to contain
> locally-bound variables. The locally-bound variable that causes the
> trouble in this example is what you're writing as [_] for the [Some]
> pattern.
> Conversely, a [_] pattern may match terms containing local variables, since
> there's no need to produce a version of the matched term that can be
> dropped into other contexts.
- [Coq-Club] Program Fixpoint and finite sets, David Pereira
- Re: [Coq-Club] Program Fixpoint and finite sets, David Pichardie
- [Coq-Club] Binding variables within nested matches,
Ben Moseley
- Re: [Coq-Club] Binding variables within nested matches,
Adam Chlipala
- Re: [Coq-Club] Binding variables within nested matches, Ben Moseley
Adam Chlipala
- <Possible follow-ups>
Xavier Leroy
Stéphane Lescuyer
- Re: [Coq-Club] Program Fixpoint and finite sets, Matthieu Sozeau
Stéphane Lescuyer
