- To: Petter Urkedal <paurkedal AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Equations from match-case unifiers under refine tactic
- Date: Fri, 03 Dec 2010 15:13:04 -0500
Petter Urkedal wrote:
I want to write a function on a constrained pair type, i.e.
embedding two data components with a fact about the two. The actual
problem is a bit involved, but I think the essence is captured by an
ordered nat-pair type,
Inductive ordnatpair : Set :=
ordnatpair_intro : forall n m : nat, n<= m -> ordnatpair.
The function will utilize the hypothesis to prove facts which will
be embedded in the result. Since it's easiest to do the logic part
in Ltac, I use refine:
Definition test : ordnatpair -> nat.
Proof.
intro p.
refine match p with
| ordnatpair_intro 0 m H => _
| ordnatpair_intro (S n') m H => _
end.
But, the equations from the match-cases are not made present when
proving the goals corresponding to the two holes
This is easy to solve using what I call the convoy pattern in CPDT (http://adam.chlipala.net/cpdt/):
refine (fun p => match p with
| ordnatpair_intro n m H =>
match n return n <= m -> nat with
| O => fun H => _
| S n' => fun H => _
end H
end).
If you're getting into the Coq dependent types business, it's probably worth reading more of the book.
- [Coq-Club] Equations from match-case unifiers under refine tactic, Petter Urkedal
- Re: [Coq-Club] Equations from match-case unifiers under refine tactic, Adam Chlipala
Petter Urkedal
- [Coq-Club] About tactic inversion,
AUGER Cedric
- Re: [Coq-Club] About tactic inversion, gallais @ EnsL.org
- [Coq-Club] About the declarative mode,
AUGER Cedric
- Re: [Coq-Club] About the declarative mode,
Ian Lynagh
- Re: [Coq-Club] About the declarative mode, Pierre Corbineau
Ian Lynagh
Matthieu Sozeau
- Re: [Coq-Club] About tactic inversion, AUGER Cedric
AUGER Cedric
Petter Urkedal
