- From: Pierre Corbineau <Pierre.Corbineau AT imag.fr>
- To: Ian Lynagh <igloo AT earth.li>
- Cc: coq-club AT inria.fr, Arnaud Spiwack <Arnaud.Spiwack AT lix.polytechnique.fr>
- Subject: Re: [Coq-Club] About the declarative mode
- Date: Tue, 07 Dec 2010 21:54:43 +0100
- Mailscanner-null-check: 1292360087.46733@VAJVHCWT8xRQiJNo8D2TlQ
- Organization: Verimag
It is because the proof term is not as trivial as for a goal-only induction.
Le 07/12/2010 20:58, Ian Lynagh a écrit :
On Mon, Dec 06, 2010 at 06:11:45PM +0100, AUGER Cedric wrote:
As often, it is very surprising that a 4 line proof in manual require
so much lines in Cezar (but also in normal mode, if you do not use
highly automated proofs).
Is this mode "frozen" (with all these flaws) or is it not?
Czar appears to be unmaintained, sadly.
I have tried to fix all bugs I (and others) have discovered over the years, but the one mentinned below as Arnaud Spiwack confessed, was introduced when merging with the new proof engine and neither he nor I have found/taken the time to meet and fix it. Perhaps now could be the time ?
There is at least one show-stopper for me:
http://www.lix.polytechnique.fr/coq/bugs/show_bug.cgi?id=2371
Thanks
Ian
Pierre Corbineau |
VERIMAG - Centre Équation | Tel: (+33 / 0) 4 56 52 04 42
2, avenue de Vignate | Office nr B7
38610 GIÈRES - FRANCE | http://www-verimag.imag.fr/~corbinea/
begin:vcard fn:Pierre Corbineau n:Corbineau;Pierre org;quoted-printable:Universit=C3=A9 Joseph Fourier - Grenoble 1;Laboratoire VERIMAG - Polytech' Grenoble adr;quoted-printable;quoted-printable:2, avenue de Vignate;;VERIMAG - Centre =C3=89QUATION ;GI=C3=88RES ;;38610;France email;internet:Pierre.Corbineau AT imag.fr title;quoted-printable:Ma=C3=AEtre de Conf=C3=A9rences tel;work:+33 (0) 4 56 52 04 42 tel;fax:+33 (0) 4 56 52 03 44 x-mozilla-html:FALSE url:http://www-verimag.imag.fr/~corbinea version:2.1 end:vcard
smime.p7s
Description: S/MIME Cryptographic Signature
- [Coq-Club] Equations from match-case unifiers under refine tactic, Petter Urkedal
- Re: [Coq-Club] Equations from match-case unifiers under refine tactic,
Adam Chlipala
Petter Urkedal
- [Coq-Club] About tactic inversion,
AUGER Cedric
- Re: [Coq-Club] About tactic inversion, gallais @ EnsL.org
- [Coq-Club] About the declarative mode,
AUGER Cedric
- Re: [Coq-Club] About the declarative mode,
Ian Lynagh
- Re: [Coq-Club] About the declarative mode, Pierre Corbineau
Ian Lynagh
Matthieu Sozeau
- Re: [Coq-Club] About tactic inversion, AUGER Cedric
AUGER Cedric
Petter Urkedal
Adam Chlipala
