- From: "gallais @ EnsL.org" <guillaume.allais AT ens-lyon.org>
- To: AUGER Cedric <Cedric.Auger AT lri.fr>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] About tactic inversion
- Date: Mon, 6 Dec 2010 18:09:55 +0100
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type; b=vDfz+lQoMoqAtH9s+t1FaF68SJsVWWlUAWz+aSpwHO+dH6NhxjWH/b4hRLtgKzGM4y Wc/kHXAN2NJfmU4SzznKY8DiqcIUx4i+I8EBO3wuxiwFi35lTpTypWu0Qr0Oagti4dW2 ZP7oZY26Uzd8drVmLzncHSabIiwdMGl5tW1Qs=
Hi Cedric,
Jean-françois Monin talked about this kind of problems in Edinburgh in August (FLOC - Coq Workshop). You might want to have a look at his paper & slides (Recent - Proof Trick: Small Inversions - http://www-verimag.imag.fr/~monin/).
Cheers,
guillaume
On 6 December 2010 16:56, AUGER Cedric <Cedric.Auger AT lri.fr> wrote:
Hi all, playing with coq terms, I was very surprised of the size of the
proof term when you use "inversion" tactic, compared to the one with a
simple manual trick.
Require Import BinPos.
Parameter ident: Type.
Parameter type_name: Type.
Parameter values: type_name -> Type.
Inductive type_stack: Type :=
| Bottom: type_stack
| Push: type_name -> type_stack -> type_stack
Notation "⊥" := (Bottom).
Notation "t ↓ s" := (Push t s) (right associativity, at level 20).
(** ** The stack index *)
Inductive stack_index (tn: type_name): type_stack -> Type :=
| Top: forall s, stack_index tn (Push tn s)
| Pop: forall s, stack_index tn s -> forall tn', stack_index tn (Push
tn' s) .
Inductive dep_type: type_stack -> Type :=
| Leaf: forall s, type_name -> dep_type s
| Dep : forall tn s, stack_index tn s -> values tn -> dep_type s ->
dep_type s | Prod: forall s, dep_type s -> dep_type s -> dep_type s
| Root: forall tn s, dep_type (Push tn s) -> dep_type s
Inductive value_stack: type_stack -> Type :=
| Vbottom: value_stack ⊥
| Vpush: forall tn, values tn ->
forall s, value_stack s ->
value_stack (tn↓s)
Fixpoint get_value1 (s: type_stack) tn (i: stack_index tn s)
: value_stack s -> values tn.
Proof.
destruct i.
intro H.
clear get_value1.
inversion H. (**)
exact X. (**)
intro H.
apply (get_value1 s tn i); clear i get_value1 tn.
inversion H. (**)
exact X0. (**)
Defined.
Fixpoint get_value2 (s: type_stack) tn (i: stack_index tn s)
Proof.
destruct i.
intro H.
clear get_value2.
(**)change (match tn↓s with ⊥ => (True:Type) | tn↓_ => values tn end).
(**)destruct H.
(**) exact I.
(**) exact v.
intro H.
apply (get_value2 s tn i); clear i get_value2 tn.
(**)change (match tn'↓s with ⊥ => (True:Type) | _↓s => value_stack s
end). (**)destruct H.
(**) exact I.
(**) exact H.
Defined.
Print get_value1. (* 96 lines of output *)
Print get_value2. (* 35 lines of output *)
Notation "'invert_stack' t" :=
(match t with Bottom => _ | _ ↓ _ => _ end) (at level 0, t ident).
(* get_value2 exploiting a notation to be of about 17 loc AND
almost readable as I consider get_value1 to be unreadable *)
Definition get_value (tn: type_name) :=
fix get_value s (i : stack_index tn s): value_stack s -> values tn :=
match i in (stack_index _ t0) return (value_stack t0 -> values tn)
with | Top s0 =>
fun vs =>
match vs in (value_stack t0) return invert_stack t0 with
| Vbottom => I
| Vpush _ v _ _ => v
end
| Pop s0 i0 tn' =>
fun vs =>
get_value s0 i0
(match vs in value_stack t0 return invert_stack t0 with
| Vbottom => I
| Vpush _ _ _ vtn => vtn
end)
end.
Is there someone working on having such proof term generation?
I admit, that before doing my inversion I put my goal in a special form
(in fact I went the furthest as possible without requiring to use
inversion, so that using inversion will be done on the smallest type)
I may be wrong, but I believe that there is no tactic doing this now.
If I am wrong, please tell it me, so my proofs will be a lot lighter
(I never use the manual trick I did here).
If you think such a tactic would be cool, I would be glad to try to
implement it (I never programmed directly a tactic in OCaml).
- [Coq-Club] Equations from match-case unifiers under refine tactic, Petter Urkedal
- Re: [Coq-Club] Equations from match-case unifiers under refine tactic,
Adam Chlipala
Petter Urkedal
- [Coq-Club] About tactic inversion,
AUGER Cedric
- Re: [Coq-Club] About tactic inversion, gallais @ EnsL.org
- [Coq-Club] About the declarative mode,
AUGER Cedric
- Re: [Coq-Club] About the declarative mode,
Ian Lynagh
- Re: [Coq-Club] About the declarative mode, Pierre Corbineau
Ian Lynagh
Matthieu Sozeau
- Re: [Coq-Club] About tactic inversion, AUGER Cedric
AUGER Cedric
Petter Urkedal
Adam Chlipala
