Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
chronological Thread
- To: Georgi Guninski <guninski AT guninski.com>
- Cc: Adam Chlipala <adam AT chlipala.net>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
- Date: Fri, 20 May 2011 11:09:38 +0200
Le Fri, 20 May 2011 12:19:04 +0300,
Georgi Guninski
a écrit :
> ...and is the "anything" type as good as False - if i rename your
> original False to FalseO and define "anything" to be False is Coq
> expected to work (possibly after modifying some proofs a bit) ?
Not well defined question.
But if you can prove (and in this case you can) that "Himpl: anything
-> False", then you can replace any binder of type "False" by a binder
of type "anything" and replace every occurence of your binder by
"(Himpl [your binder])".
Typically, "forall f: False, P f" can be replaced by
"forall a: anything, P (Himpl a)"
But "anything" and "False" are considered to be different type:
"forall a: anything, exists f: False, a = f" won't be accepted.
(but of course "forall a: anything, exists f: False, (Himpl a) = f"
will be [and will be provable])
> On Thu, May 19, 2011 at 11:41:55AM -0400, Adam Chlipala wrote:
> > Georgi Guninski wrote:
> > >what is the formal definition of "empty"
> > A type [T] is empty if you can prove [T -> False].
> > >Lemma l1: anything.
> > >Proof.
> > >constructor 1.
> > >(* this passes without plug-ins *)
> > So would running [idtac]. The problem is that you haven't finished
> > the proof. :P
- [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?,
Adam Chlipala
Georgi Guninski
Adam Chlipala
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Lauri Alanko
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
Georgi Guninski
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, AUGER Cedric
Adam Chlipala
Georgi Guninski
Adam Chlipala
