Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
chronological Thread
- To: Adam Chlipala <adam AT chlipala.net>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?
- Date: Fri, 20 May 2011 12:19:04 +0300
- Header: best read with a sniffer
...and is the "anything" type as good as False - if i rename your original
False to FalseO and define "anything" to be False is Coq expected to work
(possibly after modifying some proofs a bit) ?
On Thu, May 19, 2011 at 11:41:55AM -0400, Adam Chlipala wrote:
> Georgi Guninski wrote:
> >what is the formal definition of "empty"
> A type [T] is empty if you can prove [T -> False].
> >Lemma l1: anything.
> >Proof.
> >constructor 1.
> >(* this passes without plug-ins *)
> So would running [idtac]. The problem is that you haven't finished
> the proof. :P
- [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?,
Adam Chlipala
Georgi Guninski
Adam Chlipala
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Lauri Alanko
- Re: [Coq-Club] Can I use this nonempty inductive type in a fixpoint (without declaring variable that will lead to an axiom) ?, Georgi Guninski
Adam Chlipala
Georgi Guninski
Adam Chlipala
