- To: "Lucian M. Patcas" <lucian.patcas AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How to make the tactic ring use my ring structure?
- Date: Mon, 27 Jun 2011 13:56:03 -0400
Lucian M. Patcas wrote:
I need to define a ring structure and convince the ring tactic to use it. I looked in the manual and in the module Ring_theory. I also looked at how nat is "registered" as a ring in Coq.setoid_ring.ArithRing, but I still don't know how exactly to define a ring structure and how to use Add Ring. Perhaps I'm missing something. Can someone help out?
Perhaps you could tell us which is the first bit of Section 23.5 of the Coq manual that doesn't make sense to you? I've found it to be a reasonable guide to the use of the ring tactics.
- [Coq-Club] How to make the tactic ring use my ring structure?, Lucian M. Patcas
- Re: [Coq-Club] How to make the tactic ring use my ring structure?,
Stéphane Glondu
Lucian M. Patcas
Laurent Théry
- Re: [Coq-Club] How to make the tactic ring use my ring structure?, Lucian M. Patcas
Laurent Théry
Lucian M. Patcas
- Re: [Coq-Club] How to make the tactic ring use my ring structure?, Adam Chlipala
Stéphane Glondu
