- From: "Lucian M. Patcas" <lucian.patcas AT gmail.com>
- To: Adam Chlipala <adam AT chlipala.net>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How to make the tactic ring use my ring structure?
- Date: Mon, 27 Jun 2011 16:24:25 -0400
- Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:reply-to:sender:in-reply-to:references:from:date :x-google-sender-auth:message-id:subject:to:cc:content-type; b=rUZEFqaOsCbvVZ65EuM8xnnBEQ5Oo0dtq9Z6DawU5jejbIPTe02qW+II7iXkT6Bsr8 DH5NVbvBpPGRvOqX6+UJ3t2D6XOLEtbNYD3tvxCFf85vz7THIwBpKD5kP/dBcuoy5jI+ m17dBTQ7a/Q2i9yjfgdBfkZTbExq2t9S/PQx0=
Adam,
If it makes sense to you, that doesn't mean it makes sense to everyone. This isn't the issue, however. I didn't say the manual doesn't make sense, but that maybe I was missing something that might be obvious to someone else with more experience in this matter.
I included an example with what didn't work for me in my reply to Stephane Glondu.
Thanks.
On Mon, Jun 27, 2011 at 13:56, Adam Chlipala <adam AT chlipala.net> wrote:
Lucian M. Patcas wrote:Perhaps you could tell us which is the first bit of Section 23.5 of the Coq manual that doesn't make sense to you? I've found it to be a reasonable guide to the use of the ring tactics.
I need to define a ring structure and convince the ring tactic to use it. I looked in the manual and in the module Ring_theory. I also looked at how nat is "registered" as a ring in Coq.setoid_ring.ArithRing, but I still don't know how exactly to define a ring structure and how to use Add Ring. Perhaps I'm missing something. Can someone help out?
- [Coq-Club] How to make the tactic ring use my ring structure?, Lucian M. Patcas
- Re: [Coq-Club] How to make the tactic ring use my ring structure?,
Stéphane Glondu
Lucian M. Patcas
Laurent Théry
- Re: [Coq-Club] How to make the tactic ring use my ring structure?, Lucian M. Patcas
Laurent Théry
Lucian M. Patcas
Adam Chlipala
Stéphane Glondu
