- To: frank maltman <frank.maltman AT googlemail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Stuck on termination proof (ha ha)
- Date: Mon, 1 Aug 2011 17:01:30 +0200
Le Mon, 1 Aug 2011 15:42:44 +0000,
frank maltman
a écrit :
> On Mon, 1 Aug 2011 16:14:15 +0200
> AUGER Cedric
>Â <Cedric.Auger AT lri.fr>
> wrote:
> > Le Mon, 01 Aug 2011 08:58:39 -0400,
> > Adam Chlipala
>Â >Â <adam AT chlipala.net>
> > a écrit :
> > > frank maltman wrote:
> > > > However, I'm now stuck proving the first case that does
> > > > terminate:
> > > I don't think your question is really about Coq. This proof
> > > strategy fails on paper, too.
> > Hmm, that annoying if you consider this script:
> Thanks, both of you.
> I guess I am convinced I have an informal proof (there's one in the
> book, for a start) but at the same time, I'm likely convinced too
> easily. In this situation, I'm never sure if my approach is wrong or
> if I just don't know how to instruct coq properly. Seems as though
> it's the latter in this case.
Ok, you didn't understood my response; my script proved what you wished
(at least on my version of Coq), so that your formalization may be
wrong (the eternal problem of "how can I be sure I am in the theory I
want?"), but what you intended to prove was provable, so it doesn't seem
meaningless.
- Re: [Coq-Club] Stuck on termination proof (ha ha), Adam Chlipala
AUGER Cedric
frank maltman
- Re: [Coq-Club] Stuck on termination proof (ha ha), AUGER Cedric
- Re: [Coq-Club] Stuck on termination proof (ha ha), frank maltman
AUGER Cedric
frank maltman
Stéphane Lescuyer
AUGER Cedric
Stéphane Lescuyer
frank maltman
frank maltman
AUGER Cedric
