coq-club - Re: [Coq-Club] Stuck on termination proof (ha ha)
chronological Thread
  • From: frank maltman <frank.maltman AT googlemail.com>
  • To: AUGER Cedric <Cedric.Auger AT lri.fr>, <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Stuck on termination proof (ha ha)
  • Date: Mon, 1 Aug 2011 16:37:01 +0000
On Mon, 1 Aug 2011 17:17:16 +0200
AUGER Cedric
 wrote:
> By the way, just some informal stuff, there are several ways to
> simplify a term in coq, here I used an "unfold" followed by a "fold";
> it has the great advantage that you make the simplification you
> precisely want (simpl, tends to reduce all that can be reduced,
> without recursion unrolling, often leading to better terms, but in
> your case, it was an awful one), but the disadvantage that you have
> to find the good way to use it (provide the term in which you want it
> to be rewritten).
> A good workaround is to build opaque, but specified functions.
Thanks, I was wondering what the general approach was in that case
actually (after having seen terms reaching to hundreds of lines after
a simpl on a fixpoint definition)!
