coq-club - Re: [Coq-Club] Stuck on termination proof (ha ha)
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Stuck on termination proof (ha ha)
  • Date: Tue, 02 Aug 2011 08:48:51 -0400
To this thread where I gave incorrect advice, I wanted to try to make up for it by showing that the problem is actually quite simple to solve. Here is a nice automated solution that avoids all the issues that have been discussed in the ongoing thread. The body of the main proof looks more complex than it is because of a weakness in Ltac pattern matching on [match] expressions, where a case for each constructor must be included, even if we don't want to specify any details of those cases.
Lemma numeric_not_stuck : forall t, numeric t = true -> match one_step t with
| Result_NF t' => numeric t' = true
| Result_Next t' => numeric t' = true
| Result_Error _ => False
                                                        end.
  induction t; simpl; intuition;
    repeat (match goal with
              | [ H : _ |- _ ] => rewrite H
| [ _ : match ?E with Result_NF _ => _ | Result_Next _ => _ | Result_Error _ => _ end
|- context[match ?E with Result_NF _ => _ | Result_Next _ => _ | Result_Error _ => _ end] ] => destruct E
| [ _ : numeric ?E = true |- context[match ?E with Term_Zero => _ | Term_True => _ | Term_False => _
| Term_Succ _ => _ | Term_Pred _ => _ | Term_IsZero _ => _ | Term_Cond _ _ _ => _ end] ] =>
              destruct E
            end; simpl in *; intuition); discriminate.
Qed.
Lemma pred_numeric_not_stuck : forall (t : term),
  numeric t = true -> error (one_step (Term_Pred t)) = false.
intros t Ht; generalize (numeric_not_stuck (Term_Pred t) Ht); destruct (one_step (Term_Pred t)); tauto.
Qed.
