- To: Stéphane Glondu <steph AT glondu.net>
- Cc: Jeffrey Terrell <jeffrey.terrell AT kcl.ac.uk>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type of matched item
- Date: Tue, 23 Aug 2011 08:33:43 +0200
Le Wed, 17 Aug 2011 19:01:26 +0200,
Stéphane Glondu
a écrit :
> Le 17/08/2011 18:26, Jeffrey Terrell a écrit :
> > In f, are X and X0 the same set?
> > Inductive T : Set -> Type :=
> > Build_T : forall X : Set, T X.
> > Definition f (X : Set) (t : T X) (x : X) :=
> > match t with Build_T X0 => forall x0 : X0, x = x0 end.
> It depends on what you mean by "the same". They are not convertible,
> but you can prove that they are equal. If you need to keep some
> relation between dependencies of the type of the matched item, and
> the arguments of constructors in branches, you have to use "as ...
> in ... return ..." annotations (see the "Extended pattern-matching"
> chapter of the manual).
> In you case, by carefully taking care of dependencies, you can
> directly write:
> Definition f (X : Set) (t : T X) :=
> match t in T X return X -> _ with
> Build_T X0 => fun x => forall x0 : X0, x = x0
> end.
> Cheers,
Or even better (if your real inductive allows it):
Inductive T (X : Set): Type :=
Build_T : T X.
Whith that there is no dependency to manage as X becomes a parameter
and is no more an index (the place of X from the colon has its
importance).
- [Coq-Club] Type of matched item, Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Dimitri Hendriks
- Re: [Coq-Club] Type of matched item, David Baelde
- <Possible follow-ups>
Jeffrey Terrell
Stéphane Glondu
Jeffrey Terrell
- Re: [Coq-Club] Type of matched item, Adam Chlipala
- Re: [Coq-Club] Type of matched item, AUGER Cedric
Jeffrey Terrell
Stéphane Glondu
