coq-club - Re: [Coq-Club] Using Coq for formalization of mathematics
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Using Coq for formalization of mathematics
  • Date: Sat, 24 Sep 2011 10:59:59 -0700
On Saturday, September 24, 2011 10:29:58 AM Vladimir Voevodsky wrote:
> It is arguable whether overusing induction and Prop is of any benefit for
> the type-theoretic formalization of mathematics. In my experience one can
> formalize everything with very few uses of [ Inductive ] and no use of
> Prop at all.
> For example the use of inductive definition for "less or equal" on [ nat ]
> is unnecessary. One can define boolean less or equal [ leb ] as a
> fix-point and then define type-valued less or equal as [ Identity ( leb n
> m ) true ] . The proofs of all the properties are rather straightforward.
> Vladimir.
What about a case like "the subgroup generated by a subset"?  Using an
Inductive definition gives something which is fairly straightforward:
Inductive GeneratedSubgroup {G} `{!Group G} (S:Ensemble G) : Ensemble G :=
| GS_incl_S : forall g:G, In S g -> In (GeneratedSubgroup S) g
| GS_group_op_closed : forall g h:G, In (GeneratedSubgroup S) g -> In
(GeneratedSubgroup S) h -> In (GeneratedSubgroup S) (g*h)
| GS_inv_closed : forall g:G, In (GeneratedSubgroup S) g -> In
(GeneratedSubgroup S) (inv g)
| GS_contains_unit : In (GeneratedSubgroup S) group_unit.
You could replace the first with "Included S (GeneratedSubgroup S)".  And
maybe
(I'm not clear on this) you could even replace the last three with just "|
GS_subgroup : Subgroup (GeneratedSubgroup S)", where Subgroup is a Class or
Structure encapsulating the three conditions.  Even if not, if you give names
like ClosedUnderBinaryOp and ClosedUnderUnaryOp, you could still make it more
readable.
This is clearer, to my mind, than a definition from above as "the
intersection
of all subgroups containing S", or a definition from below as "there exists a
list of elements of G such that x is the product of the list, and each entry
in the list is either in S or the inverse of something in S".  Of course, the
second characterization could be something useful to prove afterwards, based
on the inductive definition.
Daniel
