- To: coq-club AT inria.fr
- Cc: Vladimir Voevodsky <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] Using Coq for formalization of mathematics
- Date: Sat, 24 Sep 2011 11:32:39 -0700
On Saturday, September 24, 2011 11:12:27 AM Vladimir Voevodsky wrote:
> PS Note that if one drops Prop then one also drops inductive definitions
> with values in Prop and then, for example, the definition of subgroup
> generated by a subset which Daniel writes about won't work. To replace it
> with another definition - the intersection of all the subgroups which
> contain the given subset, one needs a "resizing rule" since otherwise the
> subgroup generated by a subset will be typed to the larger universe than
> the subset itself.
I'm not sure what you mean by this. If you replace Ensemble G in my
definition
with (G->Type), then essentially what you get is the set of abstract terms in
the language of groups, with each atom coming from S (although indexed by the
evaluation in G of the abstract term). That construction shouldn't require
passing to a larger universe than the universe G is in.
Daniel
- Re: [Coq-Club] Using Coq for formalization of mathematics, (continued)
Daniel Schepler
- Re: [Coq-Club] Using Coq for formalization of mathematics, Adam Chlipala
- Re: [Coq-Club] Using Coq for formalization of mathematics, Benjamin C. Pierce
- Message not available
Daniel Schepler
Adam Chlipala
Vladimir Voevodsky
Adam Chlipala
- Re: [Coq-Club] Using Coq for formalization of mathematics, Vladimir Voevodsky
- Re: [Coq-Club] Using Coq for formalization of mathematics, Daniel Schepler
Adam Chlipala
Vladimir Voevodsky
Adam Chlipala
Daniel Schepler
Daniel Schepler
