- To: Victor Porton <porton AT narod.ru>
- Cc: Coq <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Where is the set theory?
- Date: Thu, 3 Nov 2011 22:08:58 +0100
>> Dear Daniel,
> I'm Victor, not Daniel.
Oops, I apologize.
> I will restate my problem again.
> I want syntax similar to the following:
> "supremum S == a".
You can define a relation "is_supremum S a" and then define a special
Notation so that you can write "supremum S == a" if you really want
to. But I would advise against it. Not every informal syntax invented
by mathematicians makes sense.
> I want the following to come true:
> "a in X /\ S is a subset of X /\ supremum S = a -> S has a supremum"
This is a triviality because you would write it as (continuing from
the file I sent):
Definition has_supremum {X : Poset} (S : X -> Prop) := exists x :
X, supremum S x.
Theorem victor_or_daniel (X : Poset) (a : X) (S : X -> prop) :
supremum S a -> has_supremum S.
(* proof left as exercise *)
> How to do it with type theory? I ZF I can define "y" in such a way that "y
> not in S" and use "supremum S == y" to denote that S has no supremum. I see
> no alternative for this in type theory except to formalize some universe of
> sets (for example ZF) and work inside this universe. So to have this syntax
> convenience ZF is essentially unavoidable (at least so it seems to me).
The alternative is to say simply
Definition has_no_supremum {X : Poset} (S : X -> Prop) := not exists x
: X, supremum S x.
Why do you want that y? Just so that you can use your informal
notation "supremum S == y" for two purposes, one of which makes little
sense? Just stop using the broken informal notation and life will be
easier.
With kind regards,
Andrej
- [Coq-Club] Where is the set theory?, Victor Porton
- Re: [Coq-Club] Where is the set theory?, Adam Chlipala
- [Coq-Club] Re: Where is the set theory?,
Victor Porton
- Re: [Coq-Club] Re: Where is the set theory?, Carlos.SIMPSON
- <Possible follow-ups>
Victor Porton
Daniel Schepler
Victor Porton
Andrej Bauer
- Re: [Coq-Club] Where is the set theory?, Daniel Schepler
- Message not available
- Re: [Coq-Club] Where is the set theory?, Victor Porton
- Re: [Coq-Club] Where is the set theory?, Andrej Bauer
- Re: [Coq-Club] Where is the set theory?, roconnor
Andrej Bauer
Victor Porton
Daniel Schepler
