- To: Victor Porton <porton AT narod.ru>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] I'm against setoids and pro ZF
- Date: Fri, 04 Nov 2011 14:48:36 -0400
Victor Porton wrote:
On the contrary in the above mentioned ZF formalization for Coq can be used
together with the rest Coq theories because a set is just a type.
I don't think this is accurate. CIC and ZF have been proved relatively consistent, but this does not yield a practical way to mix the two in Coq developments.
- [Coq-Club] I'm against setoids and pro ZF, Victor Porton
- Re: [Coq-Club] I'm against setoids and pro ZF, Adam Chlipala
- Re: [Coq-Club] I'm against setoids and pro ZF, roconnor
- Message not available
Bruno Barras
- Re: [Coq-Club] I'm against setoids and pro ZF, Bruno Barras
Bruno Barras
Matthieu Sozeau
- Re: [Coq-Club] I'm against setoids and pro ZF, Thorsten Altenkirch
roconnor
- Re: [Coq-Club] quotients,
Carlos Simpson
- Re: [Coq-Club] quotients, Andrew Cave
- Re: [Coq-Club] quotients, roconnor
Carlos Simpson
