coq-club - Re: [Coq-Club] quotients
chronological Thread
  • To: Carlos Simpson <Carlos.Simpson AT unice.fr>
  • Cc: Victor Porton <porton AT narod.ru>, Thorsten Altenkirch <txa AT Cs.Nott.AC.UK>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] quotients
  • Date: Wed, 9 Nov 2011 13:28:16 -0500 (EST)
On Wed, 9 Nov 2011, Carlos Simpson wrote:
Dear Russell,
 It seems to me that your problem is more with the choice function
than with the quotient types.
Well, I guess I find it hard to disentagle issues about quotients from issues about choice.
What about having a quotient type
with an induction principle saying that in order to
define a function X/R -> Y it suffices to define a function X-> Y
compatible with R? One can write something similar
for sections of dependent types.
 This would allow us to define your "squash" and hence to have access
to proof-irrelevance even if we don't suppose it for Prop's. It
also seems to allow for creating subtypes.
Well, this is pretty much the "proper" quotient system that I beleive Thorsten would advocate. The problems I have with it stem from my two examples: if real numbers are defined via a quotient then you cannot construct any non-constent function from the reals to the rationals, and you cannot extend a normal vector in R^3 to an orthonormal basis, even though both these can be constructed using representatives of R and R^3.
 By the way, Daniel Schepler points out that we get quotient types using
the Ensembles.Extensionality axiom which is in the standard library;
what exactly are the properties of those? i.e. do they satisfy the
induction principle?
Browsing http://coq.inria.fr/pylons/contribs/files/ZornsLemma/v8.3/ZornsLemma.Quotients.html shows that
Lemma quotient_projection_surjective: forall xbar:quotient,
  exists x:A, quotient_projection x = xbar.
depends on proof_irrelevence. This means that Schepler's use of "exists" is effectively a squashed dependent sum. Coq's rule that propositions cannot eliminate over prevents us from building a theorem of choice over propositional existential, so Schepler uses yet another axiom, constructive_definite_description, in his definition of induced_function to get around this restriction. At this point we have now thrown out any computational interpreation of the non-Prop universe. Computation in Coq can and will get stuck at the constructive_definite_description, even if you try extracting code. (Is it possible in some way to give a computational intepretation of constructive_definite_description? It would at the very least require a complete overhaul of the extraction mechanism.)
I'm not sure why Schepler suggested that he only used the
Ensembles.Extensionality axiom. This doesn't appear to be the case to me. I may be misunderstanding something here.
---Carlos
Selon
roconnor AT theorem.ca:
I am studying Coq and maybe now may attempt a practical exercise of writing
some theories.
I noticed that the Coq approach is to use setoids. In my opinion, it is
silly and contrary to what we do in informal mathematics.
From my experience, using setoids isn't particularly silly.  The same work
we do to prove functions respect equivalence relations is exactly the same
work that a traditional mathematician does to prove their function defined
on a quotient is well-defined.
Furthermore, removing quotients has some nice consequences.  Specifically
the extensional axiom of choice is distinct from the intensional theorem
of choice (see <http://r6.ca/blog/20050604T143800Z.html>).
If you deal with quotients in the traditional way, then the theorem of
choice will imply excluded middle, making the system non-constructive:
Proof.
Let P be any proposition.
Consider the relation R (a b: Bool) := {a = b} + {P}.  We can prove R is
an equivalence relation.  Suppose we could make the quotient type Bool/R.
We can traditionally prove (*) forall a : Bool/R, {b : Bool | a = [b]/R}
where [x]/R is the injection from x : Bool into Bool/R.
Thus from the theorem of choice we can conclude
we can conclude {f : Bool/R -> Bool | forall a:Bool/R, a = [f a]/R}.
We have forall x y : Bool, {x = y} + {~ x = y}, because boolean equality
is decidable and thus {f [True]/R = f [False]/R} + {~ f [True]/R = f
[False]/R}.
However (f [True]/R = f [False]/R) <-> P
  (proof, Suppose P, then R True False holds.  Thus [True]/R = [False]/R.
   on the other hand, if f [True]/R = f [False]/R, then we
   have [True]/R = [f [True]/R]/R = [f [False]/R]/R = [False]/R and thus
   R True False, and thus P holds.)
Therefore {P} + {~P}.
Qed.
Now, Thorsten would argue that this traditional approach to
quotients is wrong (and I would agree).  Doing quotients properly
in type theory would disallow step (*) and instead only admit
forall a : Bool/R, [[{b : Bool | a = [b]/R}]] where [[P]] is a squash
type, which is the type P quotiented so that all values are identified.
Now the theorem of choice won't apply.
The problem with quotients done properly is that you can never escape from
them to choose a representative.  Now you might think that this is exactly
the point of using quotients; however such strict adherence to quotients
severely limits your ability to compute.
Example (1) If you define the real numbers as a quotient you can never
approximate a real number by a rational number because all computable
functions from real numbers to rational numbers have to be continuous,
which means constant in this case.  Thus you could never display any
results of real number computation.  By using setoids you still have the
option to write disrespectful functions that allow you to pick an rational
approximation that depends on the particular representative and thus
allowing you to display decimal approximations.
Example (2) If you define the real numbers as a quotient then you cannot
extend a unit vector in R^3 to an orthonormal basis in R^3 that includes
it.  Again, with proper quotients, all constructive functions from R^3 to
an orthonormal basis would have to be continuous.  By the
no-hairy-ball-can-be-combed-smooth theorem, such a continuous function is
impossible.  Again, if we use setoids we have an option of breaking free
of the equivalence relation and create a disrespectful function from R^3
to an orthonormal basis that includes it.  The construction of such a
basis will depend on the choice of representative, but the construction
can be carried out.
From these examples (and I'm sure there are many more), I conclude that
using setoids is the most flexible approach.  Using traditional quotients
makes your system non-constructive, and using proper quotients limits your
ability to compute.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
Carlos T. Simpson
C.N.R.S., Laboratoire J. A. Dieudonne, Universite de Nice-Sophia Antipolis
"Homotopy Theory of Higher Categories" now published!
Cambridge University Press, October 2011
http://www.cambridge.org/gb/knowledge/isbn/item6172978/
