coq-club - Re: [Coq-Club] I'm against setoids and pro ZF
chronological Thread
  • To: Bruno Barras <bruno.barras AT inria.fr>
  • Cc: Adam Chlipala <adamc AT csail.mit.edu>, Victor Porton <porton AT narod.ru>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] I'm against setoids and pro ZF
  • Date: Thu, 10 Nov 2011 11:13:43 -0500 (EST)
Hi Bruno,
On Thu, 10 Nov 2011, Bruno Barras wrote:
Hi Russell,
For ZF, you just need excluded-middle and TTCA (a.k.a. statement ChoiceFacts.FunctionalChoice in stdlib). TTCA alone gives you IZF (with replacement, not collection). See my "Sets in Coq, Coq in sets" paper (which is inspired from Benjamin's as the title suggests) at http://jfr.cib.unibo.it/article/view/1695 . Coq sources available at http://www.lix.polytechnique.fr/~barras/proofs/sets/index.html
I don't think this is right. As you can see from Werner's paper, Theorem 18 states that "The set theory ZF can be encoded in CCI_2 + EM + TTDA_3"
Further more, in your paper on footnote 5 on page 36 you note that the axiom used by Werner is called "Type Theoretical Description Axiom".
P.S.
BTW, it is possible to interpret Zermelo set theory in Coq without assuming excluded middle. One simply needs to use double negated existentials (and disjuctions) everywhere. One also needs to restrict separation to predicates that are double negation stable (but this restriction isn't problematic because the interpretation of all classical propositions are double negation stable). I've adapted Werner's development to do this and it all appears to work; however I haven't taken the final step (and neither did Werner) of actually proving this is in fact a model of Zermelo's set theory using first order logic. This requires defining what a model for a system in the language of first order logic is (which I just happen to have already done to prove the consistency of Peano arithmetic in my work on the incompleteness theorem :).
I don't recall if I managed to model, via this double negation encoding, ZF with TTDA but without excluded middle.
Russell O'Connor                                      <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
