coq-club - Re: [Coq-Club] Matching equalities without inequalities
chronological Thread
  • To: Marko Malikovi� <marko AT ffri.hr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Matching equalities without inequalities
  • Date: Sat, 24 Dec 2011 10:02:49 -0500
On 12/24/2011 01:04 AM, Marko Malikoviæ wrote:
can somebody explain me how can I match equality in context without
involving negation of inequality.
For example, here I am interested only for terms ?a = ?b without ?a<>  ?b:
match goal with
     | id : context [?a = ?b] |- _ =>  ...
end
Namely, ?a<>  ?b is interpreted as ~ ?a = ?b. Because it include ?a<>  ?b
in result of matching.
That's an interesting puzzle! You could definitely first match [?a = ?b] and then perform a second match which _fails_ iff [a <> b] is also matched. Whether this is sufficient depends on your context.
You might also try using a named [context] pattern, which should let you reconstitute the context with some other term plugged into the hole where [a = b] was. If you pick a sufficiently rare term (let's call it [foo] here), you can then search for [~foo] in the result, which means [a = b] occurred inside a [not].
