- To: adamc AT csail.mit.edu
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Matching equalities without inequalities
- Date: Sat, 24 Dec 2011 20:28:25 +0100 (CET)
- Importance: Normal
Dear,
Thanks for your reply but neither solution does not fit. Hypotheses in my
context are propositional expressions over arithmetic expressions.
For example (simplified):
H : a <> b \/ c = d /\ e > a \/ ...
From such hypotheses I require only an arithmetic expressions of the form
X = Y (I need them for rewriting).
Your first solution does not fit to me because I do not know whether the
same hypothesis contain expressions X = Y and X <> Y.
The second solution does not fit to me because if I put "foo" instead of
all occurences of a = b then I can have foo and ~foo in the same
hypothesis.
Thanx again,
Marko Malikovic
> On 12/24/2011 01:04 AM, Marko Malikoviæ wrote:
>> can somebody explain me how can I match equality in context without
>> involving negation of inequality.
>> For example, here I am interested only for terms ?a = ?b without ?a<>
>> ?b:
>> match goal with
>> | id : context [?a = ?b] |- _ => ...
>> end
>> Namely, ?a<> ?b is interpreted as ~ ?a = ?b. Because it include ?a<>
>> ?b
>> in result of matching.
> That's an interesting puzzle! You could definitely first match [?a =
> ?b] and then perform a second match which _fails_ iff [a <> b] is also
> matched. Whether this is sufficient depends on your context.
> You might also try using a named [context] pattern, which should let you
> reconstitute the context with some other term plugged into the hole
> where [a = b] was. If you pick a sufficiently rare term (let's call it
> [foo] here), you can then search for [~foo] in the result, which means
> [a = b] occurred inside a [not].
Dr. Sc. Marko Malikoviæ
Filozofski fakultet
Sveuèili¹te u Rijeci
Ph.D. Marko Malikoviæ
Faculty of Humanities and Social Sciences
University of Rijeka, Croatia
marko AT ffri.hr
http://www.ffri.hr/~marko
- [Coq-Club] Matching equalities without inequalities, Marko Malikoviæ
- Re: [Coq-Club] Matching equalities without inequalities,
Adam Chlipala
- Re: [Coq-Club] Matching equalities without inequalities, Marko Malikoviæ
Adam Chlipala
Adam Chlipala
Chung-Kil Hur
- Re: [Coq-Club] Matching equalities without inequalities, Chung-Kil Hur
Adam Chlipala
