coq-club - Re: [Coq-Club] Matching equalities without inequalities
chronological Thread
  • To: adamc AT csail.mit.edu
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Matching equalities without inequalities
  • Date: Sun, 25 Dec 2011 09:19:36 +0100 (CET)
  • Importance: Normal
Dear Adam,
Yes, you are right! My oversight! The term ~foo will not (during pattern
matching) involve inequality. In fact, your and Chung-Kil's suggestions
are very similar.
Thanks again,
Marko Malikoviæ
> On 12/24/2011 02:28 PM, Marko Malikoviæ wrote:
>> The second solution does not fit to me because if I put "foo" instead of
>> all occurences of a = b then I can have foo and ~foo in the same
>> hypothesis.
> Glad to hear that Chung-Kil's suggestion works.  I don't see the problem
> with using a named context, because such a context only has a single
> hole to be filled, even if the term initially found in that position
> appears multiple times in the goal.  Filling the hole will only put
> [foo] in that single position.
Dr. Sc. Marko Malikoviæ
Filozofski fakultet
Sveuèili¹te u Rijeci
Ph.D. Marko Malikoviæ
Faculty of Humanities and Social Sciences
University of Rijeka, Croatia
marko AT ffri.hr
http://www.ffri.hr/~marko
