- To: Marko Malikovi� <marko AT ffri.hr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Matching equalities without inequalities
- Date: Sat, 24 Dec 2011 17:41:10 -0500
On 12/24/2011 02:28 PM, Marko Malikoviæ wrote:
The second solution does not fit to me because if I put "foo" instead of
all occurences of a = b then I can have foo and ~foo in the same
hypothesis.
Glad to hear that Chung-Kil's suggestion works. I don't see the problem with using a named context, because such a context only has a single hole to be filled, even if the term initially found in that position appears multiple times in the goal. Filling the hole will only put [foo] in that single position.
- [Coq-Club] Matching equalities without inequalities, Marko Malikoviæ
- Re: [Coq-Club] Matching equalities without inequalities,
Adam Chlipala
Marko Malikoviæ
- Re: [Coq-Club] Matching equalities without inequalities, Adam Chlipala
- Re: [Coq-Club] Matching equalities without inequalities, Marko Malikoviæ
Marko Malikoviæ
Chung-Kil Hur
- Re: [Coq-Club] Matching equalities without inequalities, Chung-Kil Hur
Adam Chlipala
