- To: Chung-Kil Hur <gil.hur AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Positivity and Elimination Principle
- Date: Fri, 20 Jan 2012 09:18:51 -0500
Chung-Kil Hur wrote:
In the definition, p seems to occur in positive positions at least
semantically.
I don't know why coq does not accept it.
Those are positive positions, but not _strictly_ positive. I assume some semantics experts found a good reason to distinguish between the two, in the design of CIC. :)
But there is a way to get around this problem.
Inductive p : Prop -> Prop :=
| P0 : p True
| P1 : forall a b, (p a \/ p b) -> p (a\/b)
| P2 : forall a b q,
(forall c, q c -> p c) ->
(forall Q, ((q a) -> Q) ->
((q b) -> Q) ->
Q) ->
p (a\/b)
I think the above definition is equivalent to your original definition.
But, coq accepts it.
This is diabolical in a way that might be easy to miss: it only works for [Prop], or some other impredicative universe. In [Set] or [Type], it wouldn't be possible to instantiate [q] with [p], since [p] must live it a universe level higher than any universe quantified in its constructors' types.
I tried briefly to come up with an intuitive explanation of why this refactoring is "OK" for [Prop] but not [Set], but I failed. :)
- [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
- Re: [Coq-Club] Positivity and Elimination Principle,
Adam Chlipala
Chung-Kil Hur
- Re: [Coq-Club] Positivity and Elimination Principle, Adam Chlipala
- Re: [Coq-Club] Positivity and Elimination Principle, Chung-Kil Hur
- Re: [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
Jean-Francois Monin
AUGER Cédric
Adam Chlipala
Andreas Abel
Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, Daniel Schepler
- Re: [Coq-Club] Positivity and Elimination Principle, Dan Doel
Dan Doel
Andreas Abel
Adam Chlipala
AUGER Cédric
Chung-Kil Hur
Adam Chlipala
