- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club AT inria.fr, Andreas Abel <andreas.abel AT ifi.lmu.de>, Adam Chlipala <adamc AT csail.mit.edu>, AUGER C�dric <Cedric.Auger AT lri.fr>
- Subject: Re: [Coq-Club] Positivity and Elimination Principle
- Date: Fri, 20 Jan 2012 18:39:45 -0500
On Fri, Jan 20, 2012 at 4:55 PM, Daniel Schepler
wrote:
> Actually, I guess that also gives an example of a positive, but not strictly
> positive, inductive definition which would lead to a contradiction:
> Inductive X : Type :=
> | X_const : ((X->Prop)->Prop) -> X.
> If Coq allowed that definition, then X_const, being a constructor, would
> automatically be injective, leading to the contradiction from my previous
> message. (Plus, I'm not at all sure what X_rect or X_ind would look like in
> that case.)
I don't know Coq particularly well. Would that normally be subject to
eliminator restrictions, or not, because X : Type?
This actually reminds me of the injective type constructors discussion
(naturally). If you have impredicativity, you can prove that I in
(something like):
Inductive X (F : Set -> Set) : Set
is not injective. So it's a problem if it is. Your diagonalization
fails in Agda for the same reason that injective type constructors
turned out to not technically be a problem there:
data X : Set₁ where
roll : (X → Set) → X
module M (f : (X → Set) → X) where
S0 : X → Set₁
S0 t = Σ[ S ∶ (X → Set) ] (f S ≡ t) × (¬ (S t))
S0 : X -> Set1, so f S0 is not well typed.
The System F/CoC encoding, of course, won't allow you to prove
injectivity of roll. You can't even write:
out : X -> ((X -> *) -> *)
because ((X -> *) -> *) : * fails. I don't know if Coq has comparable
elimination restrictions that would restrict this type sufficiently.
-- Dan
- Re: [Coq-Club] Positivity and Elimination Principle, (continued)
Adam Chlipala
- Re: [Coq-Club] Positivity and Elimination Principle, Chung-Kil Hur
- Re: [Coq-Club] Positivity and Elimination Principle, AUGER Cédric
Jean-Francois Monin
AUGER Cédric
Adam Chlipala
Andreas Abel
Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, Daniel Schepler
- Re: [Coq-Club] Positivity and Elimination Principle, Dan Doel
- Re: [Coq-Club] Positivity and Elimination Principle, roconnor
Dan Doel
Andreas Abel
Adam Chlipala
AUGER Cédric
- Re: [Coq-Club] Positivity and Elimination Principle, Andreas Abel
- Message not available
Adam Chlipala
