- To: Andrew Polonsky <andrew.polonsky AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] dependent induction 2
- Date: Fri, 24 Feb 2012 11:07:04 +0100
- Authentication-results: mr.google.com; spf=pass (google.com: domain of pierre.courtieu AT gmail.com designates 10.204.149.198 as permitted sender) smtp.mail=pierre.courtieu AT gmail.com; dkim=pass header.i=pierre.courtieu AT gmail.com
Hello, here is a script proving your goal in v8.3 and v8.4 (14975). It
makes use of JMeq but the statement of the lemma is the one you want.
Tactic dependent generalize_eqs_vars does not seem to be documented
but one should be able to do the same by hand.
Bests
P.C.
------------8X-------------------
Require Export JMeq.
Variable A:Type.
Variable F: A -> A.
Inductive graF : A -> A -> Type := io_pair (a:A) : graF a (F a).
Goal forall (a:A) (g: graF a (F a)), g = (io_pair a).
intros a g.
dependent generalize_eqs_vars g.
intros g0 H H0.
induction g.
apply JMeq_eq.
auto.
Qed.
- [Coq-Club] dependent induction 2, Andrew Polonsky
- Re: [Coq-Club] dependent induction 2,
Arnaud Spiwack
Nils Anders Danielsson
Arnaud Spiwack
- Message not available
- Re: [Coq-Club] dependent induction 2, Arnaud Spiwack
Arnaud Spiwack
- Re: [Coq-Club] dependent induction 2, Pierre Courtieu
Adam Chlipala
Vincent Siles
- Re: [Coq-Club] dependent induction 2, Andrew Polonsky
Adam Chlipala
Arnaud Spiwack
