coq-club - Re: [Coq-Club] dependent induction 2
chronological Thread
  • From: Vincent Siles <vincent.siles AT ens-lyon.org>
  • To: Pierre Courtieu <Pierre.Courtieu AT cnam.fr>
  • Cc: Andrew Polonsky <andrew.polonsky AT gmail.com>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] dependent induction 2
  • Date: Fri, 24 Feb 2012 11:12:45 +0100
  • Authentication-results: mr.google.com; spf=pass (google.com: domain of vincent.siles AT ens-lyon.org designates 10.43.48.65 as permitted sender) smtp.mail=vincent.siles AT ens-lyon.org
Nice proof, I didn't know about generalize_eqs_vars !
You should mention that this proof introduces an axiom about JMeq:
JMeq_eq : forall (A : Type) (x y : A), JMeq x y -> x = y
V.
Le 24 février 2012 11:07, Pierre Courtieu
 a écrit :
> Hello, here is a script proving your goal in v8.3 and v8.4 (14975). It
> makes use of JMeq but the statement of the lemma is the one you want.
> Tactic dependent generalize_eqs_vars does not seem to be documented
> but one should be able to do the same by hand.
> Bests
> P.C.
> ------------8X-------------------
> Require Export JMeq.
> Variable A:Type.
> Variable F: A -> A.
> Inductive graF : A -> A -> Type := io_pair (a:A) : graF a (F a).
> Goal forall (a:A) (g: graF a (F a)), g = (io_pair a).
> intros a g.
> dependent generalize_eqs_vars g.
> intros g0 H H0.
> induction g.
> apply JMeq_eq.
> auto.
> Qed.
