- From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
- To: Andrej Bauer <andrej.bauer AT andrej.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Rewriting with "identity type in Type"
- Date: Tue, 3 Apr 2012 12:30:41 +0800
If you have a suitable version of Coq, you can even have
something more focused, during the script:
info rewrite p.
You can also manually replace "rewrite p" by:
pattern x; refine (paths_rew_r A x y _ _ p).
Now, paths_rew_r itself is no black magic, try
Print paths_rew_r.
You can even prove cow using case instead of rewrite
(rewrite <-, actually):
Proof.
case q. case p. apply idpath.
Defined.
Or, shorter:
Proof.
case q. exact p.
Defined.
Hope this helps,
JF
On Mon, Apr 02, 2012 at 11:43:44PM +0200, Andrej Bauer wrote:
> I forgot to mention that 8.4 is doing something, but it would be good
> to know what exactly. Witness this:
> (* We define an inductive type which looks like [eq] but lives in [Type]. *)
> Inductive paths {A : Type} (x : A) : A -> Type := idpath : paths x x.
> (* Let us try to rewrite with it. *)
> Lemma cow {A} (x y z : A) (p : paths x y) (q : paths y z) : paths x z.
> Proof.
> rewrite p. (* It works! *)
> rewrite q. (* It still works! *)
> apply idpath.
> Defined.
> Print cow.
> (* Output:
> test =
> fun (A : Type) (x y z : A) (p : paths x y) (q : paths y z) =>
> paths_rew_r A x y (fun x0 : A => paths x0 z)
> (paths_rew_r A y z (fun y0 : A => paths y0 z) (idpath z) q) p
> : forall (A : Type) (x y z : A), paths x y -> paths y z -> paths x z
> Argument A is implicit and maximally inserted
> Argument scopes are [type_scope _ _ _ _ _]
> (* Whoa, what is this [paths_rew_r]? Black magic? *)
> (* We try the same with [eq]. *)
> Lemma bull {A} (x y z : A) (p : eq x y) (q : eq y z) : eq x z.
> Proof.
> rewrite p.
> rewrite q.
> apply eq_refl.
> Defined.
> Print bull.
> (* Output:
> bull =
> fun (A : Type) (x y z : A) (p : x = y) (q : y = z) =>
> eq_ind_r (fun x0 : A => x0 = z)
> (eq_ind_r (fun y0 : A => y0 = z) (eq_refl z) q) p
> : forall (A : Type) (x y z : A), x = y -> y = z -> x = z
> (* So paths_rew_r is like eq_ind_r. More details please! *)
> With kind regards,
> Andrej
> On Mon, Apr 2, 2012 at 11:31 PM, Andrej Bauer
> wrote:
> > What's the current status of having Coq "rewrite" working with an
> > identity type defined in Type rather than in Prop?
> > There is a patch that accomplishes this, I think (but where)? Are
> > there plans to include it in a future version?
> > With kind regards,
> > Andrej
Jean-Francois Monin
- [Coq-Club] Rewriting with "identity type in Type", Andrej Bauer
- [Coq-Club] Re: Rewriting with "identity type in Type",
Andrej Bauer
- Re: [Coq-Club] Re: Rewriting with "identity type in Type", Jean-Francois Monin
Vladimir Voevodsky
- Re: [Coq-Club] Re: Rewriting with "identity type in Type", Andrej Bauer
Andrej Bauer
