- To: Andrej Bauer <andrej.bauer AT andrej.com>, Vladimir Voevodsky <vladimir AT ias.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Re: Rewriting with "identity type in Type"
- Date: Sat, 07 Apr 2012 12:15:37 -0400
On Wed, 4 Apr 2012 10:00:33 +0200, Andrej Bauer
wrote:
> Yes, I noticed that. It actually works with any type that is defined
> just like identity, i.e., you could define your own paths as
> Inductive paths {A : Type} (x : A) : A -> Type := idpath : paths x x.
> and it would still work exactly the same. It's really nice to have
> rewriting for homotopy type theory.
So, there are two types of rewriting available in coq. The one that is
used for definitions like this, that work by eliminating an inductive
type like that above, and works for terms in arbitrary position (but not
under lambdas).
There is also a setoid based rewriting, that works over arbitrary
(Prop-based) relations, which requires an explicit proof that functions
are Proper with respect to the relation, and which does work under
lambdas. This doesn't work with relations living in Type, since it uses
> Definition relation := A -> A -> Prop.
to identify the type of relations.
<https://coq.inria.fr/bugs/show_bug.cgi?id=2440>
Tom
- [Coq-Club] Rewriting with "identity type in Type", Andrej Bauer
- [Coq-Club] Re: Rewriting with "identity type in Type",
Andrej Bauer
- Re: [Coq-Club] Re: Rewriting with "identity type in Type", Jean-Francois Monin
Vladimir Voevodsky
Andrej Bauer
- Re: [Coq-Club] Re: Rewriting with "identity type in Type", Tom Prince
Andrej Bauer
