- To: Patricia Peratto <psperatto AT adinet.com.uy>
- Cc: coqclub <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] parameter
- Date: Sat, 21 Apr 2012 14:12:52 -0400
It's certainly true that such parameter declarations act as implicit binders for the parameter variables, across the whole rest of the inductive definition. The function arrow [->] is a special case of [forall], so the _type_ of your inductive type family will involve [forall], no matter what you do, as long as there are any parameters. By definition, a type family with parameters must have all constructors' types end in instances of that type family applied to exactly the parameter variables. So, if you used an explicit [forall] in a constructor to bind a different variable to pass as the parameter value at the end of some constructor type, that would be an error. (Though you may change the parameter values in the _arguments_ of a constructor, just not the _result_ type)
I feel like I'm probably missing the heart of your question, so let me know if I haven't answered it.
Patricia Peratto wrote:
I mean by parameter the name of variable together with...
its type that one puts to the left of the : in a definition,
by example A:Type in
Inductive List (A:Type):Type
or
(A:Type) and (x:A) in
Inductive eq (A:Type)(x:A) : A->Type
Is true that with parameters and -> I don't need forall?
or is there a case in which forall is necesary?
- [Coq-Club] parameter, Patricia Peratto
- Re: [Coq-Club] parameter, Adam Chlipala
Patricia Peratto
Adam Chlipala
Patricia Peratto
Adam Chlipala
- Message not available
Adam Chlipala
Patricia Peratto
Adam Chlipala
Patricia Peratto
- <Possible follow-ups>
- Fw: [Coq-Club] parameter, Patricia Peratto
