coq-club - Re: [Coq-Club] parameter
chronological Thread
  • From: "Patricia Peratto" <psperatto AT adinet.com.uy>
  • To: "Adam Chlipala" <adamc AT csail.mit.edu>
  • Cc: "coqclub" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] parameter
  • Date: Sat, 21 Apr 2012 15:35:09 -0300
Yes, my question is other.
What I mean is if always that I have an explicit forall
in a definition I can replace it by parameters and  arrow. By example
I can write:
cons (a:A)(l:List A):List A
or
cons : A->List A->List A
instead of
cons : forall(A:A)(l:List A),List A.
My question is if I can always do it.
Regards
Patricia
----- Original Message ----- From: "Adam Chlipala" <adamc AT csail.mit.edu>
To: "Patricia Peratto"
Cc: "coqclub"
Sent: Saturday, April 21, 2012 3:12 PM
It's certainly true that such parameter declarations act as implicit binders for the parameter variables, across the whole rest of the inductive definition. The function arrow [->] is a special case of [forall], so the _type_ of your inductive type family will involve [forall], no matter what you do, as long as there are any parameters. By definition, a type family with parameters must have all constructors' types end in instances of that type family applied to exactly the parameter variables. So, if you used an explicit [forall] in a constructor to bind a different variable to pass as the parameter value at the end of some constructor type, that would be an error. (Though you may change the parameter values in the _arguments_ of a constructor, just not the _result_ type)
I feel like I'm probably missing the heart of your question, so let me know if I haven't answered it.
Patricia Peratto wrote:
I mean by parameter the name of variable together with
its type that one puts to the left of the : in  a definition,
by example A:Type in
Inductive List (A:Type):Type
or
(A:Type) and (x:A) in
Inductive eq (A:Type)(x:A) : A->Type
Is true that with  parameters and -> I don't need forall?
or is there a case in which forall is necesary?
