- From: "Patricia Peratto" <psperatto AT adinet.com.uy>
- To: "Adam Chlipala" <adamc AT csail.mit.edu>
- Cc: "coqclub" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] parameter
- Date: Sat, 21 Apr 2012 16:12:29 -0300
In case of a formation rule, can I replace in an inductive declaration of a type a forall
by parameters and arrow?
----- Original Message ----- From: "Adam Chlipala" <adamc AT csail.mit.edu>
To: "Patricia Peratto"
Cc: "coqclub"
Sent: Saturday, April 21, 2012 3:45 PM
Patricia Peratto wrote:
Yes, my question is other.
What I mean is if always that I have an explicit forall
in a definition I can replace it by parameters and arrow. By example
I can write:
cons (a:A)(l:List A):List A
or
cons : A->List A->List A
instead of
cons : forall(A:A)(l:List A),List A.
My question is if I can always do it.
Ah, I see. None of your code above uses "parameters," following official Coq terminology; that only applies to this sort of argument binding at the level of an inductive definition, not a constructor.
However, the first kind of constructor type shorthand notation you demonstrate above _is_ general enough to work for all constructor types. Of course, one of the constructor arguments (or the result) might itself have a [forall] type, in which case you need to get the [forall] in there somehow; none of the shorthands you've shown will help avoid that.
- [Coq-Club] parameter, Patricia Peratto
- Re: [Coq-Club] parameter,
Adam Chlipala
Patricia Peratto
Adam Chlipala
- Re: [Coq-Club] parameter, Patricia Peratto
Adam Chlipala
- Message not available
- Re: [Coq-Club] parameter, Adam Chlipala
Adam Chlipala
Adam Chlipala
Patricia Peratto
- <Possible follow-ups>
- Fw: [Coq-Club] parameter, Patricia Peratto
Adam Chlipala
