coq-club - Fw: [Coq-Club] parameter
chronological Thread
  • From: "Patricia Peratto" <psperatto AT adinet.com.uy>
  • To: "Adam Chlipala" <adamc AT csail.mit.edu>
  • Cc: "coqclub" <coq-club AT inria.fr>
  • Subject: Fw: [Coq-Club] parameter
  • Date: Sat, 21 Apr 2012 20:25:40 -0300
Assume I define:
Inductive Eq : forall (A:Type)(x:A),A->Type :=
|refleq : forall (A:Type)(x:A),Eq A x x.
I can instead define Eq with parameters and arrow as follows
Inductive Eq (A:Type)(x:A):A->Type:=
|refleq: Eq A x x.
The question is if I can avoid to use forall and use instead parameters and arrow.
----- Original Message ----- From: "Adam Chlipala" <adamc AT csail.mit.edu>
To: "Patricia Peratto"
Cc: "coqclub"
Sent: Saturday, April 21, 2012 4:19 PM
Subject: Re: [Coq-Club] parameter
Patricia Peratto wrote:
In case of a formation rule, can I replace in an inductive declaration of a type a forall
by parameters and arrow?
I'm afraid I don't understand again.  Another example, please?
Cc: "coqclub"
Sent: Saturday, April 21, 2012 3:45 PM
Yes, my question is other.
What I mean is if always that I have an explicit forall
in a definition I can replace it by parameters and  arrow. By example
I can write:
cons (a:A)(l:List A):List A
or
cons : A->List A->List A
instead of
cons : forall(A:A)(l:List A),List A.
My question is if I can always do it.
Ah, I see. None of your code above uses "parameters," following official Coq terminology; that only applies to this sort of argument binding at the level of an inductive definition, not a constructor.
However, the first kind of constructor type shorthand notation you demonstrate above _is_ general enough to work for all constructor types. Of course, one of the constructor arguments (or the result) might itself have a [forall] type, in which case you need to get the [forall] in there somehow; none of the shorthands you've shown will help avoid that.
